Engine dieing / cutting out
Aaronmk4
Evening,
I've posted before about this problem but I have still not manages to solve the issue.
When the car is warmed up driving and I come to a stop the car will have a slight hunt 400-600rpm and then cut out as soon as you start it she runs perfect for a mile or so and then does it again....
I've changed the fuel filter twice and inspected / cleaned out the fuel tank, is there anything else I can do?
Any ideas will be a massive help as its driving me nuts!!
I had this problem not long ago, car would cut out when slowing down to a stop and cut out. Turned out my ICV (Idle Control Valve) mentioned by Keron above was a bit groggy...cleaned it all up and viola, smooth running again. Worth a look.
  • 2 weeks later...
