Glanza_Mike Posted January 5, 2017 Share Posted January 5, 2017 Hi guys, so I've just 'bought' Sheefas Halfords battery off him that he ran on his UK spec Supra. I didn't realise that UK and Japanese cars have different battery terminals. The ones on this battery are bigger than the ones on my cars wiring loom. I'm presuming quite a few of you will have fitted a UK battery into an import Supra before? What's the best way to go about this? thanks, Mike. Link to comment Share on other sites More sharing options...
ibby Posted January 5, 2017 Share Posted January 5, 2017 This is terrible for Sheets to do this to you. Bad man. On a serious note when you mean bigger do you mean that the actual battery terminal connector slips over the new battery. If so.. You can bend the battery connector on the wiring loom to make a more sung fit. Or replace the connectors on the wiring loom side. Or use washers as spacers on the bolt giving you the ability to make it more tighter Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 5, 2017 Share Posted January 5, 2017 Think I had the same problem with mine back when I first bought it. Used a quick release battery connector instead Link to comment Share on other sites More sharing options...
Glanza_Mike Posted January 5, 2017 Author Share Posted January 5, 2017 This is terrible for Sheets to do this to you. Bad man. On a serious note when you mean bigger do you mean that the actual battery terminal connector slips over the new battery. If so.. You can bend the battery connector on the wiring loom to make a more sung fit. Or replace the connectors on the wiring loom side. Or use washers as spacers on the bolt giving you the ability to make it more tighter /QUOTE] Thanks for the reply mate, but the opposite, the battery terminal connector on the loom is too small for the connector/lugs on the new UK battery. Link to comment Share on other sites More sharing options...
ibby Posted January 5, 2017 Share Posted January 5, 2017 Will it not expand ? And use a longer 10mm bolt Link to comment Share on other sites More sharing options...
Kendo11 Posted January 5, 2017 Share Posted January 5, 2017 Think I had the same problem with mine back when I first bought it. Used a quick release battery connector instead That. HCB005 and some quick release terminal connectors. Link to comment Share on other sites More sharing options...
Glanza_Mike Posted January 5, 2017 Author Share Posted January 5, 2017 Hey guys, how do the quick release connectors solve the problem? Link to comment Share on other sites More sharing options...
a98pmalcolm Posted January 5, 2017 Share Posted January 5, 2017 Thats odd the Battery was from me Originally and Mine what J-Spec Link to comment Share on other sites More sharing options...
Kendo11 Posted January 5, 2017 Share Posted January 5, 2017 Hey guys, how do the quick release connectors solve the problem? Sorry not quick release on mine, these ones: https://www.google.co.uk/search?q=stinger+battery+terminals&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjyj_-HlavRAhVKIcAKHZAXDpoQ_AUICSgC&biw=1366&bih=633#imgrc=6yEZNkBmam_ZHM%3A Tighten up around the terminal. Link to comment Share on other sites More sharing options...
keron Posted January 5, 2017 Share Posted January 5, 2017 if your car is a facelift, it has a smaller battery and terminals. uk and jap spec prefacelifts are the same battery and fitment Link to comment Share on other sites More sharing options...
Scooter Posted January 5, 2017 Share Posted January 5, 2017 http://www.mkivsupra.net/vbb/showthread.php?270124-Battery-Terminal-advice&highlight=battery+terminals You could do what Iky did at the end of the above thread. Link to comment Share on other sites More sharing options...
Wez Posted January 5, 2017 Share Posted January 5, 2017 Correct, UK has larger terminal. I just fitted new larger battery connectors which I also purchased from Halfords When I had an NA I got a replacement Yuasa battery from AllParts so didnt need to change terminals. Link to comment Share on other sites More sharing options...
Sheefa Posted January 5, 2017 Share Posted January 5, 2017 Thats odd the Battery was from me Originally and Mine what J-Spec Don't think it was Paul. I bought yours and a new one and think I sold yours to Jake (Ripped_Fear) but can't remember which way round. Both were practically new anyway. Must be an easy fix. Link to comment Share on other sites More sharing options...
Sheefa Posted January 5, 2017 Share Posted January 5, 2017 Sorry not quick release on mine, these ones: https://www.google.co.uk/search?q=stinger+battery+terminals&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjyj_-HlavRAhVKIcAKHZAXDpoQ_AUICSgC&biw=1366&bih=633#imgrc=6yEZNkBmam_ZHM%3A Tighten up around the terminal. That's what I have in the rear of my car too. They're great. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted January 5, 2017 Share Posted January 5, 2017 Don't think it was Paul. I bought yours and a new one and think I sold yours to Jake (Ripped_Fear) but can't remember which way round. Both were practically new anyway. Must be an easy fix. ahh ok haha Link to comment Share on other sites More sharing options...
