James Posted January 5, 2017 Share Posted January 5, 2017 Thanks for all the feedback guys, i think i have my mind made up. 19x9.5 et15 on the front with possibly a 245 or 255 35/19. 19x10.5 et12 on the rear with 275 or 285 35/19 I can work out the spacing afterwards but they will be already pretty close to what i'm looking for. I used to have CCW Classics in 18x10 ET44 (but with a 5mm spacer, so ET39) up front with a 285/30/18 with no scrubbing issues whatsoever. I changed to 18x9.5 ET24 (with a 3mm spacer, so ET21 now) with a 245/40/18. It scrubs quite a lot. I'll need to change down to a 225 or 235 to avoid that. When the car is raised, the top of the tyre sits proud of the arch. If you go 18x9.5 ET15 with a 245 or 255 then you'll absolutely scrub. This is all presuming you have stock wings and not Ridox/TRD/custom. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 5, 2017 Share Posted January 5, 2017 They are basically brand new! Still have the receipt lol Quote Link to comment Share on other sites More sharing options...
CarlM Posted January 6, 2017 Share Posted January 6, 2017 (edited) I used to have CCW Classics in 18x10 ET44 (but with a 5mm spacer, so ET39) up front with a 285/30/18 with no scrubbing issues whatsoever. I changed to 18x9.5 ET24 (with a 3mm spacer, so ET21 now) with a 245/40/18. It scrubs quite a lot. I'll need to change down to a 225 or 235 to avoid that. When the car is raised, the top of the tyre sits proud of the arch. If you go 18x9.5 ET15 with a 245 or 255 then you'll absolutely scrub. This is all presuming you have stock wings and not Ridox/TRD/custom. James, are your fronts arches rolled? Do you think a 9J ET25 would rub? Edited January 6, 2017 by CarlM (see edit history) Quote Link to comment Share on other sites More sharing options...
