r0cknr0lla Posted January 3, 2017 Share Posted January 3, 2017 It is with a very heavy heart that I post this up as this car is my pride and joy however needs must so she has to go... First off.. If you dont agree with the price I am not interested.. Keep your comments to yourself please and please dont clutter the thread. This is a proper car so please dont waste my time either. I am not willing to break her as it will break my heart lol. So.. This car is a complete rebuild from the ground up and I have documented everything from the steps, work carried out, costs, all parts, hundreds of pictures and invoices lol. Build thread can be found here: http://www.mkivsupra.net/vbb/showthread.php… So far it has cost me over £22 000 since starting in june 2014. It took 18 months to get on the road and been changing and adding for the last year. It has done about 4000 miles in the last year since being put together and has run like a dream. It has 12 months fresh MOT and has just had new crank pulley, water pump, TT headgasket with ARP head studs, new rocker gaskets, cambelt and fluid changes in december 2016.. Done roughly 200 miles since. New front grooved brake discs and red stuff pads fitted about 500 miles ago and all 4 new tyres about 2.5k miles. New front windscreen about 1k miles. The car has been garaged since the beginning and I have a file full of loads paperwork (pictured). Good bits... Everything lol.. She is a real head turner and a lot of time and effort has gone into making her what she is. Loads of power and lots of bits on her. It has been spray in a very unusual colour (Dodge Viper pearl blue electric) and stands out a lot. Bad bits... *Front bumper has a scuff on near side (I will get the bumper resprayed before handing over). *Sills underneath the car are slightly flattened having done 70% of this build out of a tiny single garage.. This can be pulled straight though. *There is a very minor coolant leak from radiator drain plug.. Needs a new o-ring. *Centre console by gear knob is a bit loose, think a clip is broken although sure it can be tightened up somehow. *I dropped a socket down the sidewall behind rear speakers and this knocks every now and then.. Can be removed with magnet just never got around to it. *There are very light signs of bubbling around the rear windscreen even though I had all the rust sorted when she was sprayed. *Fuel injectors need cleaning from work done in December - I will send these off next week *Heater only gets luke warm *Rear windscreen demister doesnt work because of another muppet. *Minor bubbling around headlight bulbs as I didnt use heat resistant paint lol *The Competition clutch and flywheel squeak sometimes when moving off (common Im told) Think thats it... Have tried to be as thorough a possible. So specs.. This list is very long so there will be more that I have not listed.. If you want a more detailed list please let me know. 2JZ-GE cleaned, tested, refreshed with new gaskets and seals. Had roughly 130 000 miles when bought and was absolutely mint inside.. Pic attached. XS-Power T4 T61 single turbo kit running 450hp (capable of 600) Nankang NS-2R semi-slicks all round LS400 front brakes with Nitrac 8 groove black discs & red stuff pads JBL sound system with double din touch screen Clifford alarm & central locking FMIC Braced exhaust manifold - Titanium heat wrapped 4-Runner distributor NGK iridium level 7 spark plugs NGK 8mm HT leads 630cc Siemens Injectors Walbro 255 fuel pump Twin electric fans Alloy radiator SRD expansion tank Shine replica rear diffuser & centre fins Lightweight engine pulleys Adjustable cam gear pulleys New Injector seals New valve stem seals New Whifbitz tensioner 3 Inch Direnza twin filter air intake Custom oil drain & feed setup HKS Style 50mm wastegate GReddy E-manage Blue Full Decat Garage Whifbitz 3 inch Stainless mid-pipe HKS Carbon Ti exhaust W58 solid selector bushes A01B LSD Lightweight Competition Flywheel Competition Stage 4, 6 Puck Clutch Braided Clutch pipe HSD Coilovers 18 inch Work Emotion CR Kai wheels in Matt Black 25mm wheel spacers all round Braided brake lines Complete brake system refurb and colour to pearl blue White painted interior dash panels Sparco Marque seats Sparco 3 point harnesses Low mount sliding seat frames Blue LED light conversion TRD El-Glo Speedometre Black headlining and visors OMP deep dish steering wheel with Sparco detachable Boss Upper Glovebox gauge pod holder with Prosport gauges - Boost, Voltage & Oil Pressure Custom vented front wings Stainless Cooling Plate Clear spec indicators all round OEM side skirts Top Secret Front Bumper Smoothed rear wiper and all sprayers Debadged Clear tail light conversion Bonnet dampers Headlight conversion Engine bay smooth over Engine bay wiretuck Battery to boot relocation Fuse box relocation TT Head Gasket ARP head studs AEM Fuel pressure regulator Turbosmart boost controller The setup on this car should see around 550hp as is, maybe more, a standlone be even better.. I was going to sort injectors and go back to mapping but hey.. Someone else can enjoy it lol. The car has also been in September 2016 issue of Banzai mag.. I have copies to pass over. Mileage on the car is sat at 107k miles but bear in mind the odometre was from a different car than ran km and miles.. If I remember correctly the chassis and motor both did around 130k. Private plate goes with car. Any questions or more pics please shout £13 500.00 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 3, 2017 Share Posted January 3, 2017 Nice looking motor, apologies if I have missed it but what is your asking price? Link to comment Share on other sites More sharing options...
navtrd Posted January 3, 2017 Share Posted January 3, 2017 Nice car like the colour good luck with the sale. Link to comment Share on other sites More sharing options...
trebor69 Posted January 3, 2017 Share Posted January 3, 2017 Did you decide on a price? I can't seem to find it. Link to comment Share on other sites More sharing options...
r0cknr0lla Posted January 3, 2017 Author Share Posted January 3, 2017 Sorry guys lol.. Updated Link to comment Share on other sites More sharing options...
r0cknr0lla Posted January 3, 2017 Author Share Posted January 3, 2017 Nice car like the colour good luck with the sale. Cheers bud - - - Updated - - - Nice car like the colour good luck with the sale. Thanks mate Link to comment Share on other sites More sharing options...
raddys Posted January 3, 2017 Share Posted January 3, 2017 What gearbox has it got in it? Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted January 3, 2017 Share Posted January 3, 2017 As above, what box is this? 5 or 6 speed? Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 3, 2017 Share Posted January 3, 2017 Says W58 and A01B LSD in the advert Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted January 3, 2017 Share Posted January 3, 2017 Ah, just read, w58 bushes, take it it's a 5 speed? - - - Updated - - - Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 3, 2017 Share Posted January 3, 2017 Build thread here - http://www.mkivsupra.net/vbb/showthread.php?311270-94-NA-T-rebuild-project-SUB-ZERO Link to comment Share on other sites More sharing options...
formatzero Posted January 3, 2017 Share Posted January 3, 2017 Like the look of that ,wish I had some spare cash Link to comment Share on other sites More sharing options...
r0cknr0lla Posted January 3, 2017 Author Share Posted January 3, 2017 Build thread here - http://www.mkivsupra.net/vbb/showthread.php?311270-94-NA-T-rebuild-project-SUB-ZERO Thanks bud.. - - - Updated - - - Ah, just read, w58 bushes, take it it's a 5 speed? - - - Updated - - - 5 speed yes Link to comment Share on other sites More sharing options...
raddys Posted January 4, 2017 Share Posted January 4, 2017 Nice looking car mate but thats tt6 money.. even tt auto and 6 speed conversion would cost less, not being a prick, just giving you a little advice Link to comment Share on other sites More sharing options...
r0cknr0lla Posted January 4, 2017 Author Share Posted January 4, 2017 Nice looking car mate but thats tt6 money.. even tt auto and 6 speed conversion would cost less, not being a prick, just giving you a little advice TT6 are over 20k now. If you dont agree please refrain from commenting like I have asked already Link to comment Share on other sites More sharing options...
T2 MSW Posted January 4, 2017 Share Posted January 4, 2017 Nice looking car mate but thats tt6 money.. even tt auto and 6 speed conversion would cost less, not being a prick, just giving you a little advice If you can get a TT6 thats as good looking and been as well looked after as this car for £16k please can you send me the links. Link to comment Share on other sites More sharing options...
raddys Posted January 4, 2017 Share Posted January 4, 2017 Ive seen 2 sell in the past 6 months for 14k and 16k.. both decent and under 100k Theres also a vgc na-t 5 speed up for 9.5k atm Link to comment Share on other sites More sharing options...
navtrd Posted January 4, 2017 Share Posted January 4, 2017 Every cars priced different the level of work that's gone into this supra I think its worth every penny. Link to comment Share on other sites More sharing options...
r0cknr0lla Posted January 4, 2017 Author Share Posted January 4, 2017 Every cars priced different the level of work that's gone into this supra I think its worth every penny. Thank you mate Link to comment Share on other sites More sharing options...
trebor69 Posted January 4, 2017 Share Posted January 4, 2017 I sold my N/A-T with new XS power kit fitted about 6 months ago for 4.5K .....nothing wrong with it other than being auto and silver. Link to comment Share on other sites More sharing options...
Supraleeturbo Posted January 17, 2017 Share Posted January 17, 2017 Ump Link to comment Share on other sites More sharing options...
