LSD recommendations
Alex_GT
Turbo or NA? I'm guessing Turbo as you are worried about traction issues :taped: :D
Future plans? Do you know what diff you currently have fitted? The code will be on the VIN plate and a photo would confirm.
You have 2 casing sizes, small and large. The majority will say that you need the large case if you want to go single, but if you don't hammer it with hard launches and high torque a small case should survive.
E2A
It's not worth going OEM as it costs more than aftermarket for a lesser product. Waiting for someone a breaker, for someone to upgrade then buying their OEM LSD or upgrading yourself to an aftermarket jobbie is your only real sane option :)
Pre-facelift (05/1993 - 04/1996) 41301-24040 is still available and costs over 2k
Facelift 41301-14100 is still available and costs over £1600.00
Edited by Frank Bullitt (see edit history)
