LSD recommendations
Alex_GT
Turbo or NA? I'm guessing Turbo as you are worried about traction issues :taped: :D
Future plans? Do you know what diff you currently have fitted? The code will be on the VIN plate and a photo would confirm.
You have 2 casing sizes, small and large. The majority will say that you need the large case if you want to go single, but if you don't hammer it with hard launches and high torque a small case should survive.
E2A
It's not worth going OEM as it costs more than aftermarket for a lesser product. Waiting for someone a breaker, for someone to upgrade then buying their OEM LSD or upgrading yourself to an aftermarket jobbie is your only real sane option :)
Pre-facelift (05/1993 - 04/1996) 41301-24040 is still available and costs over 2k
Facelift 41301-14100 is still available and costs over £1600.00
Edited by Frank Bullitt (see edit history)
Can you see inside without having to remove the case completely from the car?
Nope.
The diff is held on the rear onto the subframe by the case/cover.
So you need to disconnect it from the subframe to do this, and at that stage the diff is practically out of the car.
