Acceptable amp draw when switched off
berg
Im just wondering what the acceptable amount of current draw on a battery is before it starts draining it?
Ive been having various problems with my car last few weeks, it seems to have a flat battery if left for a few days
Im using a calcium HCB005 which is only 12 months old
Ive done a parsitic drian test and the reading were 0.07, if i disconnect my toucan display which has a permanant live wire (for memory i guess) it drops to 0.03
The toucan is the only device ive added recently as is wired as per the instructions
Could 0.07 amps be enough to kill a battery in a few days or should i look at replacing the battery?
I have a trickle charger all set up now but if the battery is no good id rather get a new one
All batteries have a capacity rating of amp/hr and that is the number of amps to drain the battery in one hour. So if you divide your battery capacity by the drain rate you will get the time taken to drain the battery. Any current will drain the battery, its like having a full tank of liquid with a leak. The battery capacity needs to be well above the drain point to turn a starter motor so its not really much use determining the battery life anyway.
Are you measuring that between the + battery terminal and the + supply?
If you have the Halfords Calcium HCB005 that has a capacity of 62AH. So a draw of 0.07A will drain a good battery over 37 days. So if your charge is gone in a few days either you have additional battery drain you aren't measuring or the battery is not in good condition.
Thanks, it seems the drain isnt my issue then
No im using the negative, but i have tried positive too and readings were the same
Also worth taking a voltage reading across the two terminals when it's running and checking it's getting charged at 13.7volts or higher.
It reads on my toucan and link ecu software at just over 14v with the engine running
If the battery has been deep-cycled already (i.e. let go completely flat for whatever reason) then you can kiss it goodbye. Standard batteries hate being deep-cycled. When my alternator was on the way out I got a brand new battery and of course it went flat within a few days and would not accept a charge after that.
Exactly the same here mate. Mine is dead if left for more than 4 days without run or 12v trickle charger. I do think it is the Toucan, that's the only thing that has changed for me too since July when problems started.
Hmm interesting you say that
I'm wondering why it even has a permanent live connection
I've had no battery on the car for 4 days and when i put one on today all settings are still saved including chosen colour etc :think:
Thanks Chris that's interesting, so something else is amiss. Perhaps my battery is buggered but it was replaced in July with a different new one so surprised if that's the case. It's not a massive issue, just keep it on a trickle with a circuit breaker now.
/QUOTE]
Mine is only 12 months old, although i had let it go flat numerous times whilst doing all the work so that has probably knackered it
I took it back to Halfords today and surprisingly they replaced it with no Q's
Ive now hooked up my trickle charger on the new battery and i am going to remove the permanent live from the Toucan anyway as its pointless, so i should be all good
