Individual Throttle Bodies & Parts for ITB project
Richie_k83
Up for sale we have the parts I gathered for my Throttle Body Project.
Due to me selling the car and going a different route, I now have the parts up for sale for anyone wishing to go down this route.
Please note, this is NOT going to simply bolt onto the car, it still requires work and other bits to finish, which I will note further down.
So, we have a set of 6x Black Top 4AGE Individual Throttle Bodies, ready to link together. These are from the AE111 Corrolla.
I had to source 2x sets of ITB's for obvious reasons, so i have 2x spare to include in the sale.
I had a go at designing a flange to mount them on, which in turn would need welding to a trimmed down 2JZ-GE inlet manifold, its ok, but I am no engineer.
From my research, the Flange isnt thick enough and will more than likely Warp with the heat, so it needs redesigning with at least a 10mm thick piece.
I obtained an OEM inlet manifold which had been trimmed down, the end branches were removed and welded at a slight angle to give the correct position to the ITB's location.
This still needs levelling off and flange welding on. plus new brackets welding on for the OEM Fuel Rail.
Included in the sale are new Stainless 12 point ARP Nuts and Bolts, if the flange is tapped with the correct size, those bolts can be used. Also a used 2JZ-GTE Throttle Cable, which appears to be a direct fit and 6x new Toyota ITB Mounting Gaskets.
[ATTACH=CONFIG]216234[/ATTACH]
[ATTACH=CONFIG]216233[/ATTACH]
[ATTACH=CONFIG]216235[/ATTACH]
Parts required that I am aware of;
  • ECU (Standalone or Piggyback) - Greg at Protuner suggested a Link G4
  • Vacuum Distribution Block
  • Velocity Stacks
  • 2JZ throttle position Sensor - (direct fit, when turned around)
  • Thermal Barrier Inlet Manifold Gasket (Sold by a few US companies)
So thats it, price, well i am asking £400ovno delivered to UK Mainland only.
I am selling at a loss, so please dont expect a big price drop.
PM for more info.
  • 1 month later...
  • 2 weeks later...
