SupraLEDrears Posted December 20, 2016 Share Posted December 20, 2016 Hi I've been looking all over for the last 4 hours and I can't seem to locate what bearing to use or which circlip to replace on my noisy AC pulley. The TSRM shows the compressor taken apart but doesn't show a bearing in there either. I doubt that toyota will be of any help but I'm certain that it would be a standard bearing. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Ric Posted December 20, 2016 Share Posted December 20, 2016 circlip - 90099-07114 bearing/stator - 88411-2B090 clutch kit and bearing - 88410-14230 Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 20, 2016 Author Share Posted December 20, 2016 circlip - 90099-07114 bearing/stator - 88411-2B090 clutch kit and bearing - 88410-14230 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=216225&stc=1&d=1482219544 You, Sir, are a legend. Thanks! Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 20, 2016 Author Share Posted December 20, 2016 (edited) Seems you have to but the pulley for 182 plus vat to get a free bearing Edited December 21, 2016 by Harrypm82 (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 20, 2016 Author Share Posted December 20, 2016 30BGS10DSTP-NACHI is the bearing you need. 0121 585 5920 25 plus vat delivered from here. Pretty simple to get the pulley off. 10mm bolt to undo, pull compressor plate off, circlip to remove and pulley is out. Quote Link to comment Share on other sites More sharing options...
and1c Posted December 25, 2016 Share Posted December 25, 2016 It's all here .. http://www.mkivsupra.net/vbb/showthread.php?337389-Aircon-delete-power-steering-pump-support-query Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted December 26, 2016 Share Posted December 26, 2016 Don't forget to shim the clutch correctly when refitting HD Quote Link to comment Share on other sites More sharing options...
