Change Door Handles
kenpotaz
People..hope you can help.....
I'm looking to 'smooth' the general look of my soop. Looked at the 'delock' side of things but decided against this as being 6' 3" I didn't fancy climbing through the boot should the solenoid screw up or the battery go flat!
So then came up with the idea of swapping the handles for something 'flush fit' so the questions I have are.......
(1) Anyone know of an after market 'flush fit' handle swap or
(2) What's the best swap (something like a Civic or Avensis type handle?) and
(3) How easy/difficult is this and what do I need to look out for.
Cheers
Taz
  • 7 years later...
Guest supra4moe
Cheers
Taz
Sucks nobody replied to your post, did you find any handles? i came up with the same idea and came across your thread. lety me know if you've found anything please.
i have removed the handles an locks from my blue tt areo. iv got push buttons under the mirrors. To get over the climb threw issue of flat battery iv run a permenant live from the battery to under the front in a water tight box so if flat i can put a jump lead on it an get power to the battery an open the doors.
