opinions on this kit please
supradibbs
really considering buying this kit what do you guys think
62-1 single turbo kit. Absolutley nothing wrong with it, im just changing my whole system. Ive had the kit on for about 5-6 months. The kit has about 2-3k miles on it. I ran my car with this kit with STOCK ECU, STOCK fuel, NO VPC, NO SAFC......just ran it on whatever the ECU was telling the car tooand went 11.80 at 122 with a 1.76 60ft with race gas. Only want $1300!!
Comes with the following:
*Turbonetics 62-1 polished compressor with "big shaft"upgrade, .69 a/r hotside (centered exhaust housing)
*Custom made tubular manifold jet hot coated black by http://www.hyperkote.com
*HKS knockoff external wastegate
*3" Downpipe with heat wrap and O2 bung and Wideband bung welded in
*3" Midpipe with a 3" exhaust cutout (if u wanted to run open downpipe uncap it)
*3" Aluminum pipe from turbo to IC (Greddy FMIC)
*Clamps and silcone IC hose
*4" silver Intake pipe (just pipe, no filter)
nah dave the engine is still the same way round :D
but you will have a brake booster and steering column in the way ;)
most of the kits that we are seeing are for left hand drive cars though and they are fitting. the only issue i had was the steering column in the way of the oil return pipe but got round that by using an extra 45 degree fitting
