Wez Posted December 12, 2016 Share Posted December 12, 2016 Hey All, Does anyone have a stock ABS ECU easily accessible or on a bench that can do a quick check with a meter? Either that or an ABS ECU pinout? If you do can you check if the four wheel speed sensor inputs share a common ground or are floating. Thanks Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted December 12, 2016 Share Posted December 12, 2016 Is this any good to you Wez? http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details Quote Link to comment Share on other sites More sharing options...
Wez Posted December 12, 2016 Author Share Posted December 12, 2016 Useful thanks, doesnt look like it has the info I am after though. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 15, 2016 Share Posted December 15, 2016 Can't you probe 2 disconnected wheel speed sensor connectors rather than delve behind the dash? I think they share a common ground though Wez Quote Link to comment Share on other sites More sharing options...
