Drive train feels like there is some free play
samdale
Car is a TT6 vvti so small case and V161.
At slow speeds when I take my foot off the throttle I can feel/hear a bit of a clonk. Very faint, bit it's there and can be repeated. Not noticed it at any other time, just when the drive train goes from driving the rear wheel to being driven by them.
Any ideas? Some kind of mount for gearbox/diff causing one or the other to rock a bit?
Free play in drive/prop shaft joints?
What is this most likely to be?
I would suspect a slightly worn flywheel, in my experience the 6 speeds all get a bit of 'lash' is it worse in 1st/2nd at low speeds?
Also wouldn't rule out the engine mounts.
It's definitely more noticeable at low speeds but that's probably due to engine noise masking it at higher speeds. I'll have to have a bit more of an experiment but I think I can make the noise by driving at speed and just pushing the clutch pedal down and wait for the drive-->driven effect IYSWIM?
Is there any recommended ways to check/eliminate these? Flywheel is I think ~£500 plus labour
