Ignition Re-Wire
a98pmalcolm
Well unless you can get the actual connector pins at the igniter (unlikely) and new coils clips and connectors (these are available) you are going to have some old wire in equation. I've rewired an OEM ECU from the coil triggers to the ignitor and from the ignitor to the coils on a real problem child of a Supra. It's a hell of a lot of work. If you are going to the trouble of ripping your loom apart, remove everything you don't need from the ecu to the redundant items and replace the injector wiring and all power supplies both 12v and 5v. Or better still just build a new loom from scratch.
I have just bought new coil OEM packs costing me hundreds so I'd like to continue to use them. The R8 coil packs fit? They run off a 4 pin connection?
I am running a GTE engine, single turbo on syvecs.
Thanks
Mine are 120mj (They have External Heat Sinks :) ). They are from a Chevy Truck and were about £150 with the connector kits landed from US for 8. Made by AC delco. They do need a HT lead though which may put people off.
I was getting spark blow out at 1.6 bar, and my coil packs are 16 years old now so Sam at tdi said that the supra coilpacks are around 30mj of spark energy, the newer designs of coil on plug are 70mj plus for direct feed injection engines...so bigger bang!
