mikeekim89 Posted December 1, 2016 Share Posted December 1, 2016 As above really.. looking at some 12j alloys for the back of my supra. But im unsure of the ideal offset. Fronts will be 8.5-10j so advice on those too would be nice. Ive got uk spec brakes and I'm looking at Rota GTR-D. Would anyone know the ideal offsets for the fronts and more importantly the rears? Cheers Link to comment Share on other sites More sharing options...
berg Posted December 1, 2016 Share Posted December 1, 2016 Stock body or wide arch? Link to comment Share on other sites More sharing options...
ShawnPreece Posted December 1, 2016 Share Posted December 1, 2016 As Berg said we would need to know your arches if stock or wide... If wide then im running a ridox widearch kit and I use 18x10et35 on the front and then I use 18x12et20 on the rear which sit perfect imo... but need to know what your running Link to comment Share on other sites More sharing options...
ShawnPreece Posted December 1, 2016 Share Posted December 1, 2016 Just noticed you said UK brakes... im running UK brakes too and front wheels did touch the caliper just when tightened so an extra few mm out on the offset would be ideal to make things easier for fitting rather than modifying it Link to comment Share on other sites More sharing options...
mikeekim89 Posted December 1, 2016 Author Share Posted December 1, 2016 Im going ridox wide arch. Factory atm. Looking at wode arch front too possibly. Been offered both +20 and 0 on the rears and +15 on the front.. but 9.5j would this work? Link to comment Share on other sites More sharing options...
Nic Posted December 1, 2016 Share Posted December 1, 2016 12 +20 on the rear would extend beyond the stock wheel arches by around 40mm. 9.5 +15 on the front would extend beyond the stock wheel arches by around 25mm. Link to comment Share on other sites More sharing options...
mikeekim89 Posted December 5, 2016 Author Share Posted December 5, 2016 I measured, im going wide body. 35mm rear and 25mmish front too the tip of the rims too edge when fitted. Im looki g at wide arch now. Could I get away with a 25mm each side extension do you reckon as its only just over or would I have too go ridox 40-50mm wide arch? Im ideally hoping to put oem wide arches in Link to comment Share on other sites More sharing options...
