Bender Posted November 28, 2016 Share Posted November 28, 2016 Quick question does anybody knows what is the K&N oil filter model number for 2JZ GE ? It is HP-1002 ? And anybody knows if those HKS magnetic oil filter its worth the price ? Thanks Wysłane z mojego SM-G925F przy użyciu Tapatalka Quote Link to comment Share on other sites More sharing options...
Josh42 Posted November 29, 2016 Share Posted November 29, 2016 That is the correct part number, but i would recommend just sticking with stock. Quote Link to comment Share on other sites More sharing options...
Bender Posted November 29, 2016 Author Share Posted November 29, 2016 Thanks. Why you recomend siting with stock ? Is there something wrong with them ? Wysłane z mojego SM-G925F przy użyciu Tapatalka Quote Link to comment Share on other sites More sharing options...
David P Posted November 29, 2016 Share Posted November 29, 2016 Edit. Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 29, 2016 Share Posted November 29, 2016 I only ever used stock Toyota oil filters in my TT's, both cars combined covered more than 200,000 miles so see no point in using anything else Quote Link to comment Share on other sites More sharing options...
Ric Posted November 29, 2016 Share Posted November 29, 2016 The K&N ones have a socket fitment on the end of them, incredibly helpful for undoing and tightening with ease. I've never used them but i was planning to next time, whats the thoughts? Quote Link to comment Share on other sites More sharing options...
Bender Posted November 29, 2016 Author Share Posted November 29, 2016 Yes that wrench off thing on filter can be very usefull and they not that expensive only £8.50 Wysłane z mojego SM-G925F przy użyciu Tapatalka Quote Link to comment Share on other sites More sharing options...
Bender Posted November 29, 2016 Author Share Posted November 29, 2016 Wysłane z mojego SM-G925F przy użyciu Tapatalka Quote Link to comment Share on other sites More sharing options...
Wez Posted November 29, 2016 Share Posted November 29, 2016 Wouldn't bother with the HKS filter, you can get magnetic sump plugs which cant do any harm. I get my filters, plugs, oil etc all from OpieOils on here Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted November 29, 2016 Share Posted November 29, 2016 If you were dead against using the original Toyota one you could use one from a Lexus SC430. It's a larger V8 oil filter, part number 90915-YZZJ4. Here is a link to the magnetic sump plug - http://www.mkivsupra.net/vbb/showthread.php?316265-Gold-Plug-Magnetic-Sump-Plugs-now-available Quote Link to comment Share on other sites More sharing options...
Bender Posted November 29, 2016 Author Share Posted November 29, 2016 If you were dead against using the original Toyota one you could use one from a Lexus SC430. It's a larger V8 oil filter, part number 90915-YZZJ4. Here is a link to the magnetic sump plug - http://www.mkivsupra.net/vbb/showthread.php?316265-Gold-Plug-Magnetic-Sump-Plugs-now-available Any benefits using that Lexus V8 filter ? Wysłane z mojego SM-G925F przy użyciu Tapatalka Quote Link to comment Share on other sites More sharing options...
Wez Posted November 29, 2016 Share Posted November 29, 2016 If you were dead against using the original Toyota one you could use one from a Lexus SC430. It's a larger V8 oil filter, part number 90915-YZZJ4. Here is a link to the magnetic sump plug - http://www.mkivsupra.net/vbb/showthread.php?316265-Gold-Plug-Magnetic-Sump-Plugs-now-available those are also sump plugs I use. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted November 29, 2016 Share Posted November 29, 2016 I run a Lexus V8 filter with a Goldplug magnetic sump plug Quote Link to comment Share on other sites More sharing options...
David P Posted November 29, 2016 Share Posted November 29, 2016 (edited) This what I use, shown here next to a stock one, it ups the oil capacity by a litre and has the useful nut head. It goes here on a relocation kit, where it's in a cool draft and out of the way, it's easy to get at and helps cool the oil. Edited November 29, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
binfieldx Posted November 29, 2016 Share Posted November 29, 2016 (edited) nvm was thinking of a different filter Edited November 29, 2016 by binfieldx edit (see edit history) Quote Link to comment Share on other sites More sharing options...
ibby Posted November 29, 2016 Share Posted November 29, 2016 This what I use, shown next to a stock one. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=121978&d=1279153970 I heard wrong size does matter! Quote Link to comment Share on other sites More sharing options...
David P Posted November 29, 2016 Share Posted November 29, 2016 Increasing filter surface area, increasing oil capacity and improving cooling, can only be good things. Quote Link to comment Share on other sites More sharing options...
ibby Posted November 29, 2016 Share Posted November 29, 2016 How do you even fit that on? The stock one just about fits. Quote Link to comment Share on other sites More sharing options...
Style Posted November 29, 2016 Share Posted November 29, 2016 How do you even fit that on? The stock one just about fits. /QUOTE] Plenty room in the NA for them Quote Link to comment Share on other sites More sharing options...
David P Posted November 29, 2016 Share Posted November 29, 2016 How do you even fit that on? The stock one just about fits. /QUOTE] I knew you would ask that and posted a pic,but I had overlooked that telephone posting turns forum into fum. http://www.mkivsupra.net/vbb/showthread.php?338454-K-amp-N-oil-filter&p=4186042&viewfull=1#post4186042 Quote Link to comment Share on other sites More sharing options...
ibby Posted November 29, 2016 Share Posted November 29, 2016 Ah! What relocation kit are you using ? Quote Link to comment Share on other sites More sharing options...
David P Posted November 29, 2016 Share Posted November 29, 2016 A unlabelled pre-loved kit? The threaded adaptor was made to suit, the one it had fitted nothing, which is probably why it came cheap. Quote Link to comment Share on other sites More sharing options...
evinX Posted November 29, 2016 Share Posted November 29, 2016 I change my oil every 6 months and use these, K&N PS-1002, i purchased a load so i dont have to wait for one filter at a time http://www.ebay.co.uk/itm/PS-1002-K-N-Performance-Oil-Filter-Toyota-Suzuki-Saab-Mazda-Lexus-K-And-N-Part-/222187622545?hash=item33bb6a1091:g:NI4AAOSwtnpXiOPa Quote Link to comment Share on other sites More sharing options...
