Jellybean Posted November 28, 2016 Share Posted November 28, 2016 Price: 100 Euro Location: Ireland Dublin Used for 400 KM , replaced it with a Bosch Motorsport Inline Regulator FSE RACE Adjustable Fuel Pressure Regulator for fuel injected vehicles. Helps to maintain constant fuel pressure when running higher boost and fuel rail pressure. Designed for modified performance vehicles. This advanced fuel pressure regulator can be used as a static fixed pressure valve or for variable vacuum/turbo pressure. The valve has max flow of 5lts/min, is adjustable from 1.5 bar to 6 bar, 1:1 ratio designed for mapping and has been tested up to 10 bar. This unit is a good choice for turbo charged vehicles. Supplied with - jic 6 fitting and standard fixing bracket Male fittings that screw into the regulator are 1/8 NPTF. Link to comment Share on other sites More sharing options...
Jellybean Posted January 19, 2017 Author Share Posted January 19, 2017 Bump Link to comment Share on other sites More sharing options...
Jellybean Posted February 13, 2017 Author Share Posted February 13, 2017 Bump Link to comment Share on other sites More sharing options...
