Low revving and shaking when stopped
Karl M N
As the title explains my car is shaking when I come to a stop. It's also dropping it's revs to about 600rpm. Cold starts just fine, also runs fine when moving.
It's a TT auto.
Only modification that's been made recently is a fmic. However this occurred before my battery died and the fmic was done while it was charging so I doubt this is contributing.
The car had essentially been sitting for about a month. It did this one time before my battery died and the car was sat for two weeks after. Did t have much fuel in it, so is it possible for the fuel system to have suffered some damage due to bad fuel?
I've been looking at a few possibilities for this and to be honest I just wanna know the worst case scenario in terms of cost.
Thanks
EDIT: just a little update. The shaking and low revving has now stopped. Car pulls just fine. Can't explain that but thanks for the responses guys. I'll no doubt be back when it starts doing it again the next time I think I've finally got everything working 100% on this thing
Edited by Karl M N (see edit history)
When you come to a stop, shift it to Park or Neutral and does the shaking go/lessen considerably?
First sign of engine mounts is vibration at a stop when in 'D' or 'R'. The revs dropping though could be something completely different, from a semi seized alternator pulley, to idle control issue.
IMO unless your car is a facelift you can rule out the engine mounts as being a cause, even then the vibration comes on gradually and it sounds like this is something that's happened more suddenly?
We experienced a problem with one of our cars recently (as in a month ago) that kept running rough or even cutting out completely and the garage we went to said they suspect a problem with water in supermarket fuels at the moment as they have seen a spate of people reporting the same problem. You might just need a full tank of non supermarket fuel and maybe throw in a cleaning additive for good measure. After 3 tank fills the car is now running fine again.
Thanks for the quick responses as usual guys. Most of you are suggesting engine mounts/gearbox mounts which is something I suspected. I would hope it is this as I believe it's the cheapest fix if I'm not mistaken. The shaking has been a sudden change. Could someone also explain why bad mounts would affect the rpm though?
As for the dash rattling, I'll have to double check when I'm home. Although now that you mention it I have heard a few vibrations here and there for a while
Mounts nowt to do with idle speed. I guess that's the ECU having a senior moment. My idle sometimes wobbles around 600 and even lower when stopped. Next time I use her it can be totally fine.
If persistent, an ECU reset (pull relevant fuse or neg battery lead) usually fixes it... till the next time :blink:
My negative lead has already been disconnected. The battery was out for a few days while charging
