Jellybean Posted November 23, 2016 Share Posted November 23, 2016 Hey 2JZGTE Jspec BPU, Fuchs 10W60 Oil, Installed 264 Tomei poncam's ,in the car about 600 miles ago ; they have developed a ticking noise when hot , on idle and runs in tandem with rpm They where dialed in as per Tomei spec, silent in operation or as per OEM on installation , pre/post mapping and for about 500 miles after Unorthodox racing pulleys , locking nuts are still all secure Common cams need re-shimming after run in? Will take the covers off the weekend to check , what should I look for? Parts fitted at the same time TBELT -- Gates racing Kevlar OEM TENSIONER ASSY, CHAIN, NO.1 OEM IDLER SUB-ASSY, TIMING BELT, NO.1 OEM ABSORBER SUB-ASSY, BELT TENSIONER ATI Crank Pulley Billet Tensioner Bracket Billet Aux pulleys fitted & idler Billet upper Shock arm Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 23, 2016 Share Posted November 23, 2016 Things I would check: Whilst car is running, unplug each coil one at a time and see if noise goes away with an individual cylinder or not. Valve Clearance Check that there are no hot spots, oil build ups etc. Check shims are not slipping/weird angle Rotate crank manually with 22mm spanner with cam covers off and check for noise. Check for any damages to valve springs. Mechanic with an oscilloscope would be nice to check whilst car is driving. Loosen cambelt and check your adjustable cams are still tight when they have no tension from cambelt Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 23, 2016 Author Share Posted November 23, 2016 Thank You Quote Link to comment Share on other sites More sharing options...
ibby Posted November 24, 2016 Share Posted November 24, 2016 I assume.. you are using the right grade of oil! Quote Link to comment Share on other sites More sharing options...
rider Posted November 24, 2016 Share Posted November 24, 2016 I assume.. you are using the right grade of oil! /QUOTE] When the recommended oils for the 2JZ engine was SAE 10W30 oils I do wonder why some prefer to use a 60 weight oil. Quote Link to comment Share on other sites More sharing options...
ibby Posted November 24, 2016 Share Posted November 24, 2016 Maybe what you are hearing a combination type of oil and more strain on the springs, valves.. shims Could need adjustment. Don't know mate. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 24, 2016 Author Share Posted November 24, 2016 I had 10W40 and 10W50 in there , 3 Supra specialists told me to use 10W60, oil is only in there 3 days Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 24, 2016 Share Posted November 24, 2016 Were they ticking before the oil change mate? A 60 weight oil does seem a bit excessive for a BPU'd road car. Whether it could lead to the top-end noise you're describing is beyond my limited knowledge though. Quote Link to comment Share on other sites More sharing options...
Annabella Posted November 24, 2016 Share Posted November 24, 2016 I had 10W40 and 10W50 in there , 3 Supra specialists told me to use 10W60, oil is only in there 3 days So has it been noisy since or before swapping oil spec? Doh should have refreshed before posting! Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 24, 2016 Author Share Posted November 24, 2016 Were they ticking before the oil change mate? A 60 weight oil does seem a bit excessive for a BPU'd road car. Whether it could lead to the top-end noise you're describing is beyond my limited knowledge though. Oil weight has no bearing on the noise , it occurred approx after 500-600 miles since work was carried out I always ran , 40/50 weight but three specialists said 60 weight ; I do not think oil is a factor Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 24, 2016 Share Posted November 24, 2016 Get a video of the noise up Quote Link to comment Share on other sites More sharing options...
