Inconel vs billet compressors
Attero
Forgive me for my ignorance if I haven't quite understood something here.
I'm looking to get my standard j spec turbos rebuilt and the rebuilders I'm talking to have suggested that if I wanted a little bit more power from them without blowing them up, I should upgrade to inconel.
What would be the cons and pros to upgrading to inconel over billet?
Should I be asking for billet? Or is there no point?
Just want a little extra kick if I'm going to be rebuilding! :)
Edited by Attero (see edit history)
Second hand set would still be better :D
Problem is finding a set that has less miles than mine did and then them breaking up soon anyway
Aren't you running hybrids? Seem to recall you saying you were when I met you at wroxall abbey (thinking of the same guy I'm sure).
Yea that was me mate and they were broken! Didn't realise until Lee had them apart they were broken. So was the exhaust valve. I was lucky as Jamie's set were good so had those.
What is it about hybrid turbos that makes them unreliable? I mean it is a major concern of mine, but I don't know how common this is.
Who did your rebuild?
Hybrid turbo manufacturers just don't have the R&D facilities, quality control, and budget to compete with the big manufacturers. When you know you're going to be selling a product by the millions, reliability is far more of a concern.
It's not the blades that are the problem with rebuilding J-Spec turbos, it's the shafts. The shafts were designed for ceramic blades, and when rebuilt with steel blades they tend to fail.
Your best options are finding a set of knackered UK turbos and get those rebuilt, or buy a second hand set off J-Specs and fit those.
Sorry for the late reply mate but as Jay said really. Mine was also due to the fact contamination was left in the intake by a third party.
Mine were built by turbo dynamics. Although knowing what I do now I won't get hybrids ever again. It's just safer not to. Plus I've listened to Lees advice and the car is perfect now.
My experience and opinion on rebuilt turbo concurs with Lee's. Also most used, stock front turbo turbine castings are cracked around the wastegate port. If you can afford, and still get. new ones and intend keeping the car long term, get those. The Jap spec turbos were a LOT more reliable from new than the UK spec one. Although still a risk I would prefer known good used Jap spec turbos to rebuilt ones.
