sean17650199 Posted November 18, 2016 Share Posted November 18, 2016 I was driving my car and started to accelerate out of a corner when it slowed down to a stop and wouldn't start again it turns over but just won't start. I put the looped wire in the diagnostic box and got error 14 any ideas of where I should start with this would be much appreciated, I believe its ignition related but I'm not all that clued up on this stuff. Thanks Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 18, 2016 Share Posted November 18, 2016 Can you manually check if you are missing fuel or ignition? Error 14 is an ignition error. Basically there is a signal that tells the ignition system when to fire, and when the ECU does not receive this it will make error 14 occur. Is your car NA or TT? Quote Link to comment Share on other sites More sharing options...
sean17650199 Posted November 18, 2016 Author Share Posted November 18, 2016 Car is NA, I can take a video of it when I turn the key if that would help I just don't have a clue with this sort of stuff Quote Link to comment Share on other sites More sharing options...
sean17650199 Posted November 18, 2016 Author Share Posted November 18, 2016 http://cloud.tapatalk.com/s/582ef30d61dc5/VID_20161118_105436.mp4 Quote Link to comment Share on other sites More sharing options...
Ric Posted November 18, 2016 Share Posted November 18, 2016 Ignition error so start from the beginning. Distributor and cap/points, HT leads, plugs possibly borrow another Ignitor incase thats failed. Quote Link to comment Share on other sites More sharing options...
walkerstrider Posted November 18, 2016 Share Posted November 18, 2016 Possibly ignition fuse? Quote Link to comment Share on other sites More sharing options...
sean17650199 Posted November 18, 2016 Author Share Posted November 18, 2016 I'll give all that a go first then where would be best place to buy a new ignitor I've had a search for a few of the things it might be but can't find some of the stuff, I was planning refreshing the stuff in the engine bay anyway so don't mind buying new stuff. I checked the fuse and changed it to try that changed a few others while I was at it too. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted November 18, 2016 Share Posted November 18, 2016 IGF - Broken igniter by the sound of it. You need to test the IGF wire between the ecu and the igniter for continuity also. Quote Link to comment Share on other sites More sharing options...
sean17650199 Posted November 18, 2016 Author Share Posted November 18, 2016 Cool I'll give that a look then it will be a few days before I'd be able to get the parts but will let yous know if it gets sorted or not. Thanks Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 18, 2016 Share Posted November 18, 2016 Also worth checking that any ground have not come loose in the passenger footwell and on intake manifold Quote Link to comment Share on other sites More sharing options...
sean17650199 Posted November 23, 2016 Author Share Posted November 23, 2016 Thanks for the help guys and to keron for supplying the part much appreciated it was the igniter in the end. the supra lives to fight another day[emoji4] Quote Link to comment Share on other sites More sharing options...
David P Posted November 23, 2016 Share Posted November 23, 2016 And thank you for posting and resolving your technical thread. Quote Link to comment Share on other sites More sharing options...
keron Posted November 23, 2016 Share Posted November 23, 2016 Glad my part sorted you out mate Quote Link to comment Share on other sites More sharing options...
