Is this repairable? PLEASE any info would HELP
flatstanley
Anything is repairable and very hard to tell if the subframe is damaged or not without inspecting it, i'd be inclined
to to replace the whole corner (all the suspension arms and hub) and then get it on a wheel alignment machine
and see where it sits.
Can't tell with the subframe as you haven't shown any good pictures of it.
The subframe mounting points are easy to see though.
Two at the front is held by a vertical bolt each side.
At the back, it's held be a bracket each side.
One but on each hold the subframe to the bracket, and the bracket is held to the chassis via 4 bolts each side.
Also the anti roll bar is held on this bracket.
If they all look fine I'd be inclined to say the subframe is ok and it was just the wishbones that are bent.
