Jellybean Posted November 16, 2016 Share Posted November 16, 2016 Hi Virgin Media box I have some bad connectivity spots in the the apartment , each room has an Ethernet port , was thinking of using an extender in the Bedroom and run it off the Ethernet access point , setup a second network , the device will use the network with the best signal I dont have a spare router knocking around Was thinking BT 11ac Dual-Band Wi-Fi Extender 750 Kit OR NETGEAR EX3700-100UKS AC750 Mbps Any advice? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 16, 2016 Share Posted November 16, 2016 Seems like a lot of faff. Just buy a WIFI powerline kit, have one myself for the last few years and no issues Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 16, 2016 Author Share Posted November 16, 2016 Seems like a lot of faff. Just buy a WIFI powerline kit, have one myself for the last few years and no issues powerline kit? Running over copper wire? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 16, 2016 Share Posted November 16, 2016 powerline kit? Running over copper wire? Runs over the mains, won't make a difference if you are using WiFi. Could be a limitation if you were running hardlines. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 16, 2016 Author Share Posted November 16, 2016 I have Cat 5/6 Ethernet ports wired in all rooms , alot quicker than using copper Quote Link to comment Share on other sites More sharing options...
stevie_b Posted November 16, 2016 Share Posted November 16, 2016 I would do one of two things: 1) Just use one or two wifi extenders, like the ones you linked to. They don't use a 2nd network. or 2) Use a wireless access point. Instead of using the original wifi signal from your router to rebroadcast it, these pick up the internet from your ethernet sockets and broadcast that. Give it the same wifi name and password as your primary wifi, and your devices should swap between them relatively easily (a few seconds delay if you're walking about, perhaps). Quote Link to comment Share on other sites More sharing options...
Wez Posted November 16, 2016 Share Posted November 16, 2016 As per Stevies post above, if you create new SSID dont expect your device to just jump networks, I have found that most mobile devices will hang onto the connected wireless network as long as possible even though a much stronger network is available. Multiple AP via the CAT5/6 wiring with same SSID and passcode is what I would do too Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 16, 2016 Share Posted November 16, 2016 I have Cat 5/6 Ethernet ports wired in all rooms , alot quicker than using copper That's easy then, just set up another wireless point somewhere along the network where reception is poor. Quote Link to comment Share on other sites More sharing options...
