jonny mac Posted November 15, 2016 Share Posted November 15, 2016 hi guys, trying to setup my cams at the moment but I'm struggling to understand the cam gear sheet http://www.briancrower.com/makes/toyota/cam_card/bc_0331.pdf it says -1 ATDC intake open, surely this would be 1 degree before tdc? and the exhaust close -9 btdc? why have negative numbers? all I was hoping to get was a reading saying at such and such degree of crank rotation, the cam must be at full lift however, the sheet is only telling you when the camshaft should open/close, no center line for max lift? Quote Link to comment Share on other sites More sharing options...
David P Posted November 15, 2016 Share Posted November 15, 2016 -1 TDC = 1 degree before TDC. Quote Link to comment Share on other sites More sharing options...
jonny mac Posted November 15, 2016 Author Share Posted November 15, 2016 -1 TDC = 1 degree before TDC. yeah, I get that however why would they have it like that? why not just say 1* btdc? instead of -1ATDC? Quote Link to comment Share on other sites More sharing options...
David P Posted November 15, 2016 Share Posted November 15, 2016 Yankanese. Tomatoes tomato's. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 18, 2016 Share Posted November 18, 2016 I suspect they are probably made in China, and we have all seen Chinese instructions.... Are they symmetric lobes? If so you can probably work out where full valve lift should occur. Quote Link to comment Share on other sites More sharing options...
jonny mac Posted November 23, 2016 Author Share Posted November 23, 2016 got it sorted, bc emailed me back saying it's to do with maths for adding up duration apparently cams are now dialled in correctly Quote Link to comment Share on other sites More sharing options...
David P Posted November 23, 2016 Share Posted November 23, 2016 -1 TDC = 1 degree before TDC. Quote Link to comment Share on other sites More sharing options...
