SupraTRD_MK4 Posted July 26, 2018 Share Posted July 26, 2018 Nice. Mind if I ask what you pay for the cowling fan blade? Quote Link to comment Share on other sites More sharing options...
inazone Posted July 26, 2018 Share Posted July 26, 2018 Well bit of funny update,had some free time this morning so decided to try find electrical problem on supra. After checking all my earths were tight and clean, checked my sensor connections and everyone seemed fine. So thought I know would do the paperclip trick to work out what code flashing, only to open to diagnostic box to find this....lol https://jza80.mkivsupra.net/imports/2018/07/393.jpg https://jza80.mkivsupra.net/imports/2018/07/394.jpg Did make me laugh, when see the paperclip, I must of forgotten about it when 1st started engine up (total idiot lol). At least now that’s one problem sorted put key in and no flashing engine light....funny happy day.[emoji23][emoji23][emoji23][emoji23] Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted July 26, 2018 Author Share Posted July 26, 2018 Nice. Mind if I ask what you pay for the cowling fan blade? I can’t remember how much paid for cowling, got it couple years ago. The fan itself I got from Whifbitz for £201 delivered. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted August 29, 2018 Author Share Posted August 29, 2018 (edited) Haven’t updated this for a month as been busy building reptile viv’s. So few weeks ago I purchased from member on hear front crash bar modified to fit bomex front bumper, when it turned up the ends looked bit of mess. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted August 29, 2018 Author Share Posted August 29, 2018 (edited) Update part 2. I fitted the front crash bar, refitted front cross member, fitted new timing cover and trimmed cam cover to fit also I fitted and plumbed in oil cooler. The oil cooler is only temporary fitted as waiting for intercooler to turn up so can fit oil cooler in right position. I ordered the Whifbitz NA-T on 3rd August and Paul said would be 3-4 weeks delivery so waiting now for that to turn up now to continue with build, I also spoke to lee at SRD about battery relocation kit so once turbo kit fitted will get that ordered and fitted. To protect engine bay from heat of turbo I have purchased DEI titanium heat wrap to cover manifold and downpipe plus cover for turbo it’s self. I ran the car this weekend for good 30 minutes to test for leak on oil cooler and get oil up to temperature and double check everything still fine and no leaks in preparation of turbo kit turning up. Forgot to add I also finished wiring the nos system back into engine bay, bleed power steering system and painted and refitted spark plug cover. Fingers crossed turbo kit turns up soon so can get that heat wrapped and fitted, then make brackets for oil cooler at work and get front wings painted/refitted then just need to orders new bomex bumper and carbon bonnet. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 5, 2018 Author Share Posted December 5, 2018 (edited) Right haven’t updated this awhile duo to being mega busy at work and life plus drilled thought hand while working on build and couldn’t hold spanner or ratchet for about 3 weeks, but the build is making good progress now, so will try to bring my thread upto date tonight. On the 12th October my Whifbitz na-t kit turned up, was so excited to finally have kit and gave kit really good look over and was very impressed and pleased with the quality of the kit. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 5, 2018 Author Share Posted December 5, 2018 (edited) Sorting pics Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 5, 2018 Author Share Posted December 5, 2018 (edited) 1st job on list was I wanted to test fit the log manifold as was aware the studs needed cutting down so wanted to find out by Then I wanted to get intercooler fitted into place, which was really easy to fit . Once them jobs were done and studs cut down I fitted the log manifold, wastegate and turbo, plus also heat wrapped the screamer pipe and fitted that to wastegate ready. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 5, 2018 Author Share Posted December 5, 2018 (edited) Once that was all out way I wrapped new exhaust pipe and fitted that aswell as downpipe, haven’t wrapped downpipe yet as currently have the lambda sensors fitted so once everything fitted can test for leaks using n/a ecu. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 5, 2018 Author Share Posted December 5, 2018 (edited) On Black Friday I treated myself to a Link G4+ Ecu. Last few weeks have been struggling with the turbo oil lines, have to 1st an quite shocked and surprised that the oil lines don’t come pre made on the turbo kit, but that’s one of them things. So ordered AN spanner set but none of them fitted the fittings so spent next two weeks ordering different sets and sending them back until finally got few that fitted the fittings, I managed to get the oil feed on but still haven’t got the drain on as the hose wasn’t in great condition so had 50mm cut off from place near me and now line isn’t long enough, so have asked mate who works at Perkins to make up some hose so fingers crossed should have that soon and can fit rest of turbo kit mainly the intercooler pipes. Once kit all fitted will fire her up again and check for leaks and make sure everything working fine. I still have the SRD battery relocation kit to fit and move the screen wash bottle into boot. I have had to remove the Nos solenoids and lines from engine bay as no longer fit on hot side with the turbo, will be having the nos system reinstalled once get FFIM next year. On 17th December will be collecting my freshly painted front wings and can get lights and bonnet refitted so she starts looking like car again. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 9, 2018 Author Share Posted December 9, 2018 (edited) Some more news on my build, mate managed to make up new oil drain hose for me Also managed to find company who are going to 3D print an ecu box for my new Link G4, so looking forward to cin it made and how it looks, As bringing supra out next year decided to do proper insurance quote as last couple years just had her on a garage policy while doing build, went with Adrian Flux and have declared all mods with £30k agreed value for £420 for the year, over the moon with my policy. Today decided to fit drain hose and intercooler pipe work in the hope of starting her up for her 1st time with turbo, but unfortunately when started fitting pipework noticed that was missing one pipe and two silicone joiners from kit so have emailed Whifbitz in the hope they send them out this week without any problems. Am missing the one that goes from bottom off turbo to intercooler pipework under radiator, slightly annoyed about it but one of them things I guess. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 9, 2018 Share Posted December 9, 2018 The link ecu P&P board is meant to be installed into your old ECU case btw. Just unscrew the screws that hold your currently NA ECU motherboard in place and link ecu will bolt in place. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 9, 2018 Author Share Posted December 9, 2018 The link ecu P&P board is meant to be installed into your old ECU case btw. Just unscrew the screws that hold your currently NA ECU motherboard in place and link ecu will bolt in place. The Link ecu doesn’t fit the n/a ecu box, it’s designed to fit the GTE ecu and not tearing apart a GTE 6speed ecu just for the box Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 9, 2018 Share Posted December 9, 2018 The Link ecu doesn’t fit the n/a ecu box, it’s designed to fit the GTE ecu and not tearing apart a GTE 6speed ecu just for the box I've fitted one to NA box before Quote Link to comment Share on other sites More sharing options...
P_Bazz Posted December 9, 2018 Share Posted December 9, 2018 Very nice build, love all the attention to details! Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 9, 2018 Author Share Posted December 9, 2018 I've fitted one to NA box before I was told the link g4 wouldn’t fit in na box, but will be interesting to see the 3D printed box Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 9, 2018 Author Share Posted December 9, 2018 Very nice build, love all the attention to details! Thank you so much, have given this build my all and really appreciate it when people say they like what I have done Quote Link to comment Share on other sites More sharing options...
blackdevilcar Posted December 10, 2018 Share Posted December 10, 2018 Wow, that looks great Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 10, 2018 Author Share Posted December 10, 2018 Wow, that looks great Thank you very much Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 17, 2018 Author Share Posted December 17, 2018 Slight update with build, picked up my freshly painted front wings Saturday, can’t wait to get them fitted over Christmas holiday, plus had email today and my 3D printed ecu case will be sent out tomorrow so really can’t wait to see how that looks. Have emailed Whifbitz about missing intercooler pipe and should have it after Christmas am still not very happy as waited 9 weeks as he was having problem with intercooler pipe quality and sent out kit with no pipe and now can’t start up engine after waiting so long, it’s doing my head in. Will post up pictures of ecu case when turns up. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 23, 2018 Author Share Posted December 23, 2018 (edited) Well little update with build, have finally got the turbo oil drain fitted, plus have completely removed nos system from engine bay, will be reinstalling it once get FFIM as will be going direct port but have no room in engine bay as all the nos solonoids and lines were situated where turbo now sits. Plus something really interesting came in post yesterday my 3D printed ecu case for my link G4, it looks really good and can’t wait to get it all fitted. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 28, 2018 Author Share Posted December 28, 2018 (edited) Made some good progress on Sophie today, finally got the wings and bonnet fitted, haven’t got them all lined up perfect yet just wanted to get them on out way and fitted so could focus on getting battery and screen wash fitted into boot, that’s my next job after had good tidy up in garage. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
inazone Posted December 28, 2018 Share Posted December 28, 2018 Looking good mate, need to pop round and have a proper look! [emoji3] [emoji106] Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted December 28, 2018 Author Share Posted December 28, 2018 Looking good mate, need to pop round and have a proper look! [emoji3] [emoji106] /QUOTE] Cheers bud, she’s getting there now soon be hunting season for her[emoji4][emoji106] Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted March 3, 2019 Author Share Posted March 3, 2019 (edited) Well haven’t updated this for quite a while, haven’t made great progress build last few months due to old knee injury, but have been doing few bits. Finally got all the wings lined up properly and bolted on, plus have had old scuttle panel repainted and fitted with new OEM rubber seal. Also the missing intercooler pipe from Whifbitz finally turned end of January so attempted to fit that but he had sent wrong joiner so after few hours had lost my temper and threw pipe damaging it. He never said sorry but did admit was his fault for sending wrong joiner. Well today in garage I managed to finally fit said pipe and joiner, had to cut water hose and remove anti roll bar just to get in on but at least it’s done now, also managed to get rest on intercooler pipe work all connected and drivers side headlight fitted, want to mount oil cooler before fit passenger headlight. She’s all ready to fire up now for 1st time since starting to fit Whifbitz na-t kit. Will properly fire her up in week and let run for 30minutes on idle just to check everything, also going to order new bomex front bumper soon so can get that painted and fitted. Was planning to have car on road in April but don’t think that will happen now as saving money just incase need operation on knee and could be off work for few months. Edited June 10, 2020 by Suprakeith (see edit history) Quote Link to comment Share on other sites More sharing options...
