bradleyh_15 Posted March 11, 2024 Share Posted March 11, 2024 Been polishing your tip all night hey 2 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 11, 2024 Author Share Posted March 11, 2024 28 minutes ago, bradleyh_15 said: Been polishing your tip all night hey Been polishing it so hard it went blue! 1 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 13, 2024 Author Share Posted March 13, 2024 (edited) Another day of new parts.. Flywheel, clutch, V160 oil, spoiler grommets, clutch master cylinder and under bonnet insulation all arrived from Whifbitz today. reallllyyyy want to get back out in this again now! Just want to get everything bed in nicely and then launch the shit out of it! Edited March 13, 2024 by HarleyFDMD (see edit history) 4 Link to comment Share on other sites More sharing options...
Wind Walker Posted March 16, 2024 Share Posted March 16, 2024 Easy on the launch mate you know how long it’s taken us to source v160s. Loving it so far keep it up. 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 16, 2024 Author Share Posted March 16, 2024 4 hours ago, Wind Walker said: Easy on the launch mate you know how long it’s taken us to source v160s. Loving it so far keep it up. Haha! Hey bro! Nah im sending this once its built again! Didn't launch it once last yeah because i was scared of breaking the R154. Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 16, 2024 Author Share Posted March 16, 2024 Got the spoiler painted today at last. Forgot to take a photo of it once it was finished though.. also had a TRS steering wheel cover arrive and some ARP wheel studs as one of my rear wheel studs sheared off and i hadn't even been driving the car particularly hard. I did some research on these beforehand though and discovered that they are actually for a lexus IS300. They do fit Supra but the initial part of the stud where it presses into the hub needs to be shaved done a touch.. theres a very useful thread on here that i followed. I put a drill in a vice with a cable tie around the trigger, put the stud in the drill and using a mini belt sander shaved off the bit that was necessary. Worked perfectly. Did all 10 studs in about 5 minutes. 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 17, 2024 Author Share Posted March 17, 2024 Really loving the oem spoiler again 2 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 19, 2024 Author Share Posted March 19, 2024 Cleaned up the driveshafts last night, used our aqua blaster which always does a good job of things like this. Used it on a very low pressure mind you and aimed it in the opposite direction of where the CV boots seal! This evening I'll use some Por15 metal etch on them and them paint them. Should look nice and new then 4 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 23, 2024 Author Share Posted March 23, 2024 (edited) Some updates from the past few days.. Firstly, got the driveshafts finished. After aqua blasting them i painted them in epoxy primer and then used buzz weld WAR as a top coat as i had some left over from my truck and thought it was good stuff! Then last night we got the car loaded back onto the trailer and bought back into work Edited March 23, 2024 by HarleyFDMD (see edit history) 2 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 23, 2024 Author Share Posted March 23, 2024 When i removed the old gearbox i went on a side quest and started stripping part of the floor pan. I finished off removing this section of underseal and wire wheeled any surface corrosion down before using Jenolite to tackle anything that remained. Once that had worked its magic i used Por15 metal etch and then epoxy primed it I will eventually do the whole underside but its very time consuming so I'll be doing it section at a time. Whilst waiting for the Por15 to do its thing, i also got the new flywheel on using 271 loctite so it could then dry over night. 4 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 23, 2024 Author Share Posted March 23, 2024 The following day i seam sealed the areas that i had previously epoxy primed. The tunnel itself would have been a waste of time to strip all the oem underseal off as it was pretty mint so i just gave it a top up coat of Buzzweld WAR. Tomorrow I'll also use WAR on the area i have primed once the seam sealer has set 3 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 23, 2024 Author Share Posted March 23, 2024 I then made a start on the ARP rear wheel studs. I decided to tackle this first as it was the job i was dreading most although it actually went very smoothly with the help of an old thread on here that i followed step by step. I also got the diff and shafts installed before tackling the clutch and gearbox I had some ARP bolts which i believe were designed as turbo to manifold bolts but they also happen to be the perfect size for transmission mount so in they went! Love a bit of overkill! Drained the old oil from the gearbox which fortunately was very clean, Good signs! 3 Link to comment Share on other sites More sharing options...
mwilkinson Posted March 23, 2024 Share Posted March 23, 2024 I love it when people get sucked into the rabbit hole of refurbishment. It's an easy trap to fall into It's why my car is taking so long to rebuild. I've just spent 2 weeks just rebuilding the wing mirrors! 2 2 Link to comment Share on other sites More sharing options...
evinX Posted March 23, 2024 Share Posted March 23, 2024 Nice work 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 23, 2024 Author Share Posted March 23, 2024 12 minutes ago, mwilkinson said: I love it when people get sucked into the rabbit hole of refurbishment. It's an easy trap to fall into It's why my car is taking so long to rebuild. I've just spent 2 weeks just rebuilding the wing mirrors! I always find myself venturing off on some sort of excursion away from what i had originally intended 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 24, 2024 Author Share Posted March 24, 2024 8 hours ago, evinX said: Nice work Thanks mate I have that reverse light switch plug on my list of things to do today 1 Link to comment Share on other sites More sharing options...
MrH Posted March 24, 2024 Share Posted March 24, 2024 Looking good, the underside certainly looks better after a clean up! 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 24, 2024 Author Share Posted March 24, 2024 Got into work early this morning to get this finished, removed the transmission mount first so i could finish the floor pan. Whilst i had the mount off i ran it through the aqua blaster to get it looking new again the rear discs were also looking worse for wear, they are probably 7 or 8 years old now but have covered very little mileage. I'll be buying new oem discs and pads soon but for the meantime i cleaned these discs up in the aqua blaster too and then re painted the edges. Then continued to get the last few bits done, heat shields, exhaust, driveshafts etc 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 24, 2024 Author Share Posted March 24, 2024 Once I'd pretty much finished everything (with the exception of fitting the rear wheels, engine undertray and one of the clutch inspection covers) i fired it up to make sure everything was as it should be.. select all gears / check for noises and leaks etc. Everything with the gearbox was spot on. No issues at all and i was about to throw the rear wheels on and take it for a spin but i noticed the engine note sounded a bit different to normal. Sounded like the manifold was blowing, and sure enough it was Typical! The turbo to manifold nuts had come slightly loose and blown the T4 gasket. So i began to strip that down... fortunately i had a spare T4 gasket and oil drain gasket so i managed to get it all built back up. I had some locking turbo nuts too so hopefully they'll help prevent this happening again didn't get a final picture but it all went back together easy enough and i then got the wheels on the the other small bits finished and took it out for my first drive as a 6 speed! Clutch is smooth and light and the flywheel doesn't make any untoward noises (being solid rather than oem dual mass) so all in all very happy.. obviously it'll take a few miles of driving before its properly bed in so this may change! Still need to fit the new clutch master cylinder but I'll do that in a few days. The car feels faster than it did before, not sure whether thats because of the difference in gear ratios or maybe i just need to get used to it again. Being March.. meaning colder tyres and colder tarmac may have contributed but it was spinning the tyres much more than it did before.. just ripping! 5 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 25, 2024 Author Share Posted March 25, 2024 (edited) VID-20240325-WA0132.mp4 Ahh Mexico.. gotta love it 3 people deep, rear tyres down to 20psi. Mostly hooks in 2nd but still a fair bit of wheel spin. Edited March 25, 2024 by HarleyFDMD (see edit history) 2 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 28, 2024 Author Share Posted March 28, 2024 I've had an issue with my clutch over the past couple of days. It keeps sticking to the floor. Seems worse during the first few minutes of driving whilst everythings cold. Im 99% sure its the master cylinder and i have a brand new oem one to fit. I would assume the one in the car currently is original and so 31 years old. So that's my job for the weekend and i bought 1.5L of Motul RBF700. I also bought a couple of decent quality .50mm T4 gaskets and 2 oil drain gaskets incase i blow one again. a few weeks back i also bought some titanium coloured mikalor clamps, i may have mentioned before but my plan is to get all the boost pipes re made in titanium. Still need to order a few more of the clamps in different sizes but i think they look pretty cool. 1 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted March 30, 2024 Author Share Posted March 30, 2024 Today i replaced the clutch master cylinder finally. It was definitely due! used the Motul RBF700 and adjusted the clutch pedal accordingly. Really pleased with how the clutch pedal feels.. its always a worry when you fit a performance clutch as to whether the clutch is going to be too heavy or snappy or both. This spec 3+ is perfect. Light pedal and you can slip it whilst pulling away. After some spirited driving i do get some noise through the V160 with the Spec solid flywheel but its not terrible. One thing i have noticed is some vibration at 75mpg and upwards. Pretty sure its the propshaft and i think this is because i accidentally separated it whilst i was installing it and i've thrown the balance out by not putting it back together in the same position.. so that'll be the next job!! Also today whilst i had the titanium catch can removed i polished up the top and re-burnt it as beforehand it was pretty dull! 3 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted April 13, 2024 Author Share Posted April 13, 2024 Next job for me is to sort out my sills. I know this is a typical problem for many supra owners. The sills end up flattened due to poor jacking over the years and mine were no exception. I haven't jacked my car up on the sills in years because they haven't been especially healthy. I use the box section as seen in previous photos I've posted. However sorting out the sills has always been something I've wanted to do (just other things previously took priority) The drivers side rear sill is the worst, it had actually been pushed upwards into the box section. So not only did it need straightening but it also needed pulling out. I bought a slide hammer and a body work pulling clamp. This did a really good job of pulling the sill straight and downwards. I completely forgot to take any photos afterwards though! Just straightening the sills was never going to be enough though, although the clamp and slide hammer did a good job, it wasn't perfect. Also at this point the sill is still weak, jacking on it again would just flatten it again and i dont want to keep jacking on the box section. So i bought some 3mm sheet steel and some 10mm steel 'hockey puks' to reinforce the area and then make a proper jacking point on the sill. I made a good start this evening but again forgot to take any photos. I'll try and get it finished Monday evening now i think. Then will have to do the other 3 corners! 2 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted April 15, 2024 Author Share Posted April 15, 2024 Unfortunately i didn't get as long as I'd have liked working on the car this evening. I got the inner side of the sill reinforced and got the outer side reinforcement plate made but not welded on. The outer side will probably need to be double layered to bring it level with the inner as the floor either side of the sill doesn't actually sit at the same height. Meaning it'll be 6mm thick on the outer edge. Hopefully get that done tomorrow. In the meantime i gave it a thick coat of Jenolite to sit in overnight. As for 'Hockey pucks', i decided to weld 2 together.. making them 20mm Just need to get it smoothed out now. 2 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted April 15, 2024 Author Share Posted April 15, 2024 To add to my already very colourful engine bay, i bought some titanium coloured mikalor clamps.. keeping with the titanium/purple theme. I'd already bought some a few weeks back but hadn't bought enough in the correct sizes. But I've now replaced all of the regular jubilee clips.. Im sure my engine bay is considered a bit marmite by people.. i fully appreciate its not the typical all polished, or all black engine bay that most people tend to do (because either of those options do look mega!) I just fancied doing something really in your face! 3 Link to comment Share on other sites More sharing options...
