Harleys new progress blog from the start. My Na 5
HarleyFDMD
If it helps mate, I found my old order;
It was 2018 when I ordered but was only £29.99 then.
Custom Brake Hose
Fitting One  Swivel Male - M10 x 1.00
Fitting One Angle  90°
Fitting Two  Swivel Male - M10 x 1.00
Fitting Two Angle  90°
Support One  Single Bolt Locator
Support Two  Rubber Grommet
Length  150cm
I seem to recall (with a rusty 4 year old memory) that whilst I needed the 90° for the master side, a straight would have been better at the slave?
It certainly worked with 2 x 90’s but I can’t remember the orientation of the slave so have a quick look what you thinks best.
  • 4 months later...
  • 3 weeks later...
Been finishing a few jobs this week before the car goes to SRD Saturday morning. Took the week off work because i know everything always takes longer than expected!
Started by finishing my heat shield for the clutch and brake reservoirs.
and then finished my power steering cooler lines and filled with ATF - 🤞🏻 no leaks so far!
  • Like 1
  On 2/9/2023 at 8:14 PM, TheTurtleshead said:
Looks good Harley - Where did you get that Engine bay box?
Expand
Thanks mate, i bought it from Lee Elkin-Afonso. I then cut the top off it and added the heat shielding to the side.
Once this is all done and back from SRD and i've enjoyed it over summer I'll be booking in with you for some underside work!
  • Like 1
I got all the lines installed underneath the car too. Which were the perfect length.
The kit included 4x billet fuel/brake line mounts for the centre of the car but nothing for the rear where the fuel lines route over the subframe. I had some AN8 duel line clamps which i mounted to the factory locations using some thread bar, i pinned the brake lines in the same place too using plastic P clips - all in all im pretty pleased with the result. No loose fuel lines or brake lines and all done neatly. Photos are pretty grainy due to the poor lighting under the car
i also got a mount made in the boot to accommodate the fuel pump relays. Ive left the wiring for SRD
  • Like 2
Expand
Ahhh! I thought I recognised it. I made it 🤣 Did a pair for Jake yeeeeears ago for his silver NA.
  On 2/9/2023 at 11:13 PM, HarleyFDMD said:
Thanks Keith, its been a long time coming but i can finally see the light at the end of the tunnel!
Expand
I know the feeling bud, it took me nearly 6 years to build mine and she/s still far from point want her lol, just don't do a me....had mine all running sweet back on road last year and after 10 weeks spun her and damaged front end, nothing serious just waiting now for her to go to paint and hopefully this year we will sea each other out on the road and go for nice drive out to enjoy the cars.
  • Like 1
  On 2/13/2023 at 8:19 AM, mattdavies said:
Whats are SRD doing for you ? Making the intercooler pipework I take it ? and then mapping etc ?
Expand
Yeah intercooler pipework, down pipe and mid pipe fabrication. Adding additional sensors for the Link ecu, installing the engine loom, wiring the fuel pump relays and gauges, wheel alignment, few other loose ends that need finishing and then basically getting it run in and mapped!
  • Like 1
  • 1 month later...
  • 1 month later...
  On 2/23/2023 at 6:41 PM, wile e coyote said:
great read and build
Expand
  On 4/16/2023 at 12:52 AM, Wonga Spar said:
Started reading this 3 hours ago and just couldn't stop. Way past my bedtime, but what an incredible build. Can't wait to see what SRD do for you.
Expand
Thanks guys.. its been a journey! 😅
Sometimes i look back through this myself and just laugh to myself.
  • Like 1
So I've had a couple of updates from Lee..
All the fabrication work is completed, so thats the intercooler pipe and exhaust done. They've also made a small loom for the gauges and got them working..
Assuming there's still a bit of engine bay wiring to be done and then hopefully we'll have it running soon! 😁
received_758895135960588.thumb.jpeg.f7ab4e766e98752de89b56d292b593d5.jpegreceived_559868522893581.thumb.jpeg.2e55d13eb8e926eb5477a23287dec779.jpeg
  • Like 4
