Suprakeith Posted November 10, 2016 Share Posted November 10, 2016 Hi am after best way to drain fuel from my supra, have taken car off road while rebuild engine and have about 3/4 tank of v-power and don't want it to sit in car and ruin as thinking supra will be off road most of next year Link to comment Share on other sites More sharing options...
Al Massey Posted November 10, 2016 Share Posted November 10, 2016 I went through the boot. Undid the fuel pump cover and removed the fuel pump. Then had plenty of space to get the fuel out Link to comment Share on other sites More sharing options...
Suprakeith Posted November 10, 2016 Author Share Posted November 10, 2016 That's a good idea didn't think of that, do you know if there way to switch pump on and keep it on so can put container in engine bay with hose and pump fuel out using fuel pump Link to comment Share on other sites More sharing options...
Al Massey Posted November 10, 2016 Share Posted November 10, 2016 You could remove the fuel pipe from the rail, take the fuse out for the starter and pump it out that way? Link to comment Share on other sites More sharing options...
Suprakeith Posted November 10, 2016 Author Share Posted November 10, 2016 You could remove the fuel pipe from the rail, take the fuse out for the starter and pump it out that way? Thank you for that, will give that a go Link to comment Share on other sites More sharing options...
Scooter Posted November 10, 2016 Share Posted November 10, 2016 When people change the fuel filter they often complain of the detached hose draining the tank.... Link to comment Share on other sites More sharing options...
mwilkinson Posted November 10, 2016 Share Posted November 10, 2016 I just siphoned the tank into jerry cans. Only needed a bit of hose. Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2016 Share Posted November 11, 2016 (edited) I use a banjo bolt fitted to a couple meters fuel line then bridge the diag pins, pump then drains tank EDIT: misread, I fit a line to pump feed in the boot under the cover...... Edited November 11, 2016 by Wez (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted November 11, 2016 Share Posted November 11, 2016 You can by cheap battery powered syphon, we use one on the race car. https://www.fueltankshop.co.uk/syphon-pump-battery-operated/p2261 Link to comment Share on other sites More sharing options...
Suprakeith Posted November 11, 2016 Author Share Posted November 11, 2016 Cheers guys plenty of ideas to drain the tank Link to comment Share on other sites More sharing options...
