Sandwich Plate fit with oil cooler assembly
Jellybean
Hi
I want to remove the Oil filter relocation kit but retain my 1/8 NTP oil pressure sensor
Question
Can I fit a Sandwich Plate to the oil cooler assembly and still get an oil filter on, looks a bit tight?
Sandwich Plate with Thermostat , I was thinking Mocal Thermostatic Sandwich Plate 571-OTSP1 with a 16 UNF
http://www.speedflowshop.co.uk/mocal-thermostatic-sandwich-plate-571-otsp1-1020-p.asp
Get a two way adapter so you can use the stock oil pressure location for the oil sender and stock sensor. Took me 10 minutes to get mine installed this way
Mike sorry can show me a picture what the two way adapter looks like? Where is the stock oil pressure location for the oil sender and stock sensor
AS I have a 93 Think I found my answer
http://mkiv.com/techarticles/oil_sensor_mod/index.html
90401-19008 Union Bolt
90430-20016 Gasket
90301-68005 O-ring (Optional)
Supra 1998 / 2001 Lexus IS300 Setup
Solution
It is a pita to use a T bolt on the 93- 97 Supra, as the pressure sensor is screwed into the block behind the AC compressor.
The Lexus IS300 & 98 Supra run the factory pressure sensor on the base of the union bolt connected via the Oil filter housing , easy access
It is as simple as removing the stock union bolt and replace it with the Lexus/ Supra VVTI bolt, The new OEM bolt has a 1/8 NTP sensor port
Supra 93-97 Setup
Edited by Jellybean (see edit history)
