My First Supra - Red Mkiv N/a Auto
jonny mac
  • Replies 77
Really nice to see the progress made, your exhaust system looks amazing.
You're lucky to have access to a ramp it makes working underneath so much easier.
I'm wondering if I fancy a change to red now after looking at how nice your car looks.
thanks for the comments guys :D yeah he really is awesome with a polishing pad alex!
now have some new parts for the car, a full set of uk spec brakes, a set of tein coilovers in need of a clean up, a stock steering wheel and also a few gte bits to add to the collection in prep for a swap
aye I should be along to the next one providing it fits in with work as I'm back to 6 day weeks and late evenings now
will be cool to go along though, would like to see that v8 turbo'd red one that was there last time
It's always gonna be on a Sunday afternoon if that's handier for you dude, it seems to be the best time for everyone
  • 2 weeks later...
new braided hel lines turned up
image77 by Jonny McIntosh, on Flickr
bought a spare front end to have powdercoated and polybushed in the future
image78 by Jonny McIntosh, on Flickr
however it doesn't have the mounts for the front strength braces on a supra so i'll just get another one
this setup was from a soarer but at least i've still got spare arms etc
new wheel nuts turned up, m12x1.5
image79 by Jonny McIntosh, on Flickr
got a stock wheel finally :D
image80 by Jonny McIntosh, on Flickr
Edited by jonny mac (see edit history)
bought a set of oem 17" turbo wheels :D delighted! finally....been looking for a set of these for a long time
image82 by Jonny McIntosh, on Flickr
they need a refurb and tyres done so i'll see if the powdercoating place can do them while my subframes are being done
full rear subframe from a turbo mkiv, i'm going to use all the rear end parts but polybush and powdercoat them
don't think it's an lsd but i'll open it up to check the ratio anyway as it may not be the correct diff to the chassis plate
image81 by Jonny McIntosh, on Flickr
and a full front end, again to be stripped and made pretty/new rubber bushes
image84 by Jonny McIntosh, on Flickr
the old paper speakers were dead, finally got round to replacing them
image83 by Jonny McIntosh, on Flickr
random ones in the back and alpines up front behind oem speaker grills
  • 2 weeks later...
  • 2 weeks later...
Must be nice to have plenty of cash to spend on the car ,you've done a great job
thanks dude, yeah I work 6 days a week and also most evenings to cover my habbit, drugs would have been cheaper haha!
so I've found a lad breaking a gte supra so I've bought his rear sump with oil drain, got my name down on a few other bits from his car that I'd need for BPU too
How will you do for the engine wiring ? You can't reuse the one of the N/A isn't it ?
What's the best way :
Sourcing a stock Supra wiring ?
Are some aftermarket wiring available on the market ?
this weekend I found a guy selling a supra gte turbo ecu loom so I've got my name down on that when it comes off the car, however it's a non vvt loom so I may not actually use it
my last resort would be buying a haltech 2jz2go loom and ecu but that's a big spend for what really would just be powering a few 12v wires on an ecu loom
I'll manage to get it going, weather it means leaving the ecu tucked somewhere in the engine bay for now behind the battery as the loom is too short for a supra or weather I sit down and manually lengthen /rejoin every single wire in the loom to reach the supra passenger floor
  • 2 weeks later...
true! i'll work it out later on
picked up a 2jz gte tt power steering pump this week, also a set of fmic pipework and a walbro 255lph fuel pump :D
just to buy a fmic core next, will probably just get the universal 600x300x76mm one from any motorsport place
finally got round to the supra badge!
image85 by Jonny McIntosh, on Flickr
also had my mate come by with his arch roller as i needed the inner edge raised a little at the top as it was catching the wheel under compression
you can't tell by looking from the outside, it hasn't flared the arch outwards, also i've covered the life out of it where we were working in underseal just incase the paint had split even a small amount
image86 by Jonny McIntosh, on Flickr
so a big delivery turned up one morning at work
image87 by Jonny McIntosh, on Flickr
the guys at jdm distro done an awesome job sourcing a clean engine, only thing missing in my order was the afm i'd asked to be included, they said they'd send one out
so i spent my lunch break stripping off the auto transmission that came with the engine, all bolts were still like new!
this has to be the cleanest 2jz i think i've ever seen....it must be a seriously low mileage, the block isnt even rusted on the cast outside!
so i got the engine home and put it on my spare stand and out the way for now
image88 by Jonny McIntosh, on Flickr
so far i've managed to collect:
mkiv turbo power steering pump
the banjo fitting for the brake servo
1994 turbo engine mounts
turbo rear sump with oil drain flange
fmic pipes and core
also for the loom, i'm going to extend this loom through to the footwell for now and add in efi relays and make it work with my chassis plugs for rpm signal output etc
  • 3 weeks later...
  • 4 weeks later...
updated build thread picture links in the posts, the photobucket new rules have stopped third party hosting
made a flickr account :D
i'll need to update this with new pics of what's happening with the build, progressing well with the 2j though!
moved the sidelights down to the facelift indicators
image117 by Jonny McIntosh, on Flickr
parts collection growing for the aristo engine
image118 by Jonny McIntosh, on Flickr
that's a non vvt turbo ecu and loom for a mkiv which i'll be using as my reference point for looom length etc
gte water pump (used for 100 miles) but turns out the aristo one is the same anyway!
fmic pipework, viscous fan, walbro 255lph pump
power steering pump from a mkiv, power steering bottle too
image119 by Jonny McIntosh, on Flickr
image120 by Jonny McIntosh, on Flickr
also still cleaning it pretty much weekly haha
image121 by Jonny McIntosh, on Flickr
sold the j3 autobox from the aristo engine
so take one very clean non rusty 2jz block :D
image123 by Jonny McIntosh, on Flickr
and paint it to protect it!
first coat on, note i'm not using the front sump so didn't bother me getting paint on it
image124 by Jonny McIntosh, on Flickr
second coat will go on in a weeks time, really going to let this coat harden fully before i put the second layer on
began painting the originally silver parts on the engine,
the mounts, oil drain, rear sump, starter motor, sump lower part
going to be doing the alternator etc later
unfortunately the guy who'd previously worked on these mounts has cross threaded the inside of one of them, the actual rubber mounting part not the block bracket, so i need to find another mount if i can't recut the threads straight
image125 by Jonny McIntosh, on Flickr
image126 by Jonny McIntosh, on Flickr
don't currently have any pics of it but i've since removed the aristo loom from the engine on the stand, i've now got it lay out on the work bench and have it ontop of a supra loom, so i'm basically replicating the supra length and body loom pinouts
aristo's are a little more confusing i'd say compared to the supra loom
image122 by Jonny McIntosh, on Flickr
  • 1 month later...
went out for a photoshoot last night, it was right at the time of the sun setting so made it a little tricky to get the exposure settings correct
image127 by Jonny McIntosh, on Flickr
image128 by Jonny McIntosh, on Flickr
image129 by Jonny McIntosh, on Flickr
image130 by Jonny McIntosh, on Flickr
image131 by Jonny McIntosh, on Flickr
image132 by Jonny McIntosh, on Flickr
image134 by Jonny McIntosh, on Flickr
image135 by Jonny McIntosh, on Flickr
image137 by Jonny McIntosh, on Flickr
image136 by Jonny McIntosh, on Flickr
will get the interior pics uploaded later
my favourite one of the evening
image133 by Jonny McIntosh, on Flickr
