My First Supra - Red Mkiv N/a Auto
jonny mac
Hello! My First Supra :D
just going to keep this thread updated with how i get on with the car, i'd looked around for a long time for the 'right' one
jdm import, active aero lip, oem plastic skirts and spats, gold toyota badges, all oem unmolested (even a stainless steel rep stock exhaust)
so here it is after a bath
needs alot of paint work as the top coat has peeled in areas
also has some sort of aftermarket wheels on it
eeeeeeek
image1 by Jonny McIntosh, on Flickr
underneath is good, few scrapes from coming off the truck as it wasn't a long bed, easily sorted with some fresh underseal
also the front brake pipes are great condition too which is a boost
first night in, changed the oil and a new toyota oil filter on
image2 by Jonny McIntosh, on Flickr
image3 by Jonny McIntosh, on Flickr
image4 by Jonny McIntosh, on Flickr
image5 by Jonny McIntosh, on Flickr
bought these from toyota to put on after it's painted
image6 by Jonny McIntosh, on Flickr
the brakes were in a mess on the car, so i've changed 3 calipers, thank you very much james dron for the calipers :)
also bought new toyota discs and pads
image7 by Jonny McIntosh, on Flickr
got them on, new brakes all bled and the new coat of underseal on the chassis
a very rough quick coat of black paint, please excuse that as it'll be tidied up on the second coat and around the hub on the disc
image8 by Jonny McIntosh, on Flickr
unfortunately one of the bleed nipples on james's calipers had a leaked under pressure during the mot, so
I've since rebuilt an old caliper that came off the car and put that back on now so it's due to be retested tomorrow
image10 by Jonny McIntosh, on Flickr
the car had a little almost missfire / stutter on idle so i'd replaced the plugs too
image11 by Jonny McIntosh, on Flickr
as for now, i'm waiting for the mot retest to be done and then it's off to the bodyshop for some repainting, potential full respray just in the factory colour though!
also i've got a 1jz gte/w58 manual box i pulled out my mates soarer a while ago when i sold him my engine setup from another car
Edited by jonny mac (see edit history)
  • Replies 77
Very nice Jonny :cool: although a member since 2007 and this is your first one? That's a looong time looking around for one lol :D health to drive - I think the wheels might be SSR integrals - maybe not the most 'fashionable' at the minute, but if that's what they are they're very well built and very light.
They are Advan AVS VS-5's, I used to have a set on mine. They are entry level wheels in Japan, but they are rare in the UK due to limited supply.
Looks like a nice supra dude, how is the underside?
thanks for the replies guys :D
I really am over the moon with the car and can't wait to start a journey with it! (no pun intended)
they worth anything? I was thinking on changing, they're 235 tyres up front and 255 on the rear so should be quite good rim widths
the underneath is still in fair nick for an old car, it's got no holes which is a good thing haha, it was all still mainly black from the original underseal when it first came into the uk so I don't have much to worry about,
sometime in the future I plan to refresh the underside like I've done to my silvia which was a full nut and bolt drama, not as extreme as that but I'd like to powdercoat things like subframes and diff casings etc to keep it looking fresh
the car only has 139 thousand kilometres on it which isn't a huge mileage for a 94 model.
more pics to come later once I get them off the phone :D
mot passed the other day :D
not using it on the road until next year however as it's not the right weather to take it out, plus that'll give me time to swap parts and paint it without any hurry
manual conversion parts started arriving from Toyota, I'm skint now haha
image13 by Jonny McIntosh, on Flickr
image14 by Jonny McIntosh, on Flickr
manual trans tunnel (I do things properly) also with a bag of clutch pedal bushings etc
image15 by Jonny McIntosh, on Flickr
just waiting on the rest of the pedal assembly arriving from Toyota
i'll likely just buy a length of braided Teflon lined hose and make my own clutch pipe up as it'll be better than standard
Looking good, can't wait to see this with the 1J in it. Are you just sticking with the stock twins or going nuts with a 5858? :D
Driftmotion are good for manual conversion parts too, I got all of my OEM nuts/bolts/input and output shaft seals/arp bolts from there and full length 1 piece braided clutch line etc. All very well priced.
ive provisionally sold the 1j I have now in the last few days :D haha
decided on a 2j vvti tt engine! found one from an aristo and figured, i'll have to do the water pump and timing belt regardless so the difference there won't bother me,
the loom's are not going to plug and play even if I got a 2j vvti supra loom so an aristo loom will work with providing power to b+ wires etc,
the w58 won't last though that's the only thing
  • 2 weeks later...
little update,
the car is now at the bodyshop having a full respray so it'll look immaculate
I stripped almost everything off
when it arrived at the bodyshop I took off the ariel, rear wiper, spoiler, anything else that would have kept it water tight until then
rear spats are not going back on
image16 by Jonny McIntosh, on Flickr
bumpers held on with tie wraps, skirts off too
image17 by Jonny McIntosh, on Flickr
back on a truck to get moved over to the bodyshop
image18 by Jonny McIntosh, on Flickr
spent a full day and a half prepping the car for paint, had the rear wiper hole and rear ariel hole blanked off too, i'll just run a signal booster in the boot for that
also during all this, I'd split the lights and painted the insides satin black
image19 by Jonny McIntosh, on Flickr
image20 by Jonny McIntosh, on Flickr
image21 by Jonny McIntosh, on Flickr
stevie the painter had an idea to rub down the lenses again and clear coat them with uv protection special stuff, looks amazing now :D
image23 by Jonny McIntosh, on Flickr
due to the old paint condition, it took a fair amount of rubbing down the car, this means it has now had a coat of high build primer to be sanded back again before paint
image24 by Jonny McIntosh, on Flickr
  • 4 weeks later...
last parts of the clutch pedal assembly arrived :)
image25 by Jonny McIntosh, on Flickr
also my manual surround showed up from toyota
image29 by Jonny McIntosh, on Flickr
stripped the box front end and resealed the bearing sleeve as it had a little leak
image26 by Jonny McIntosh, on Flickr
image27 by Jonny McIntosh, on Flickr
also cleaned up the flywheel, going to try get someone to skim this for me
image28 by Jonny McIntosh, on Flickr
more importantly :) :) :) :)
been a few weeks gone by and made some good progress on the car
image32 by Jonny McIntosh, on Flickr
image34 by Jonny McIntosh, on Flickr
image33 by Jonny McIntosh, on Flickr
image35 by Jonny McIntosh, on Flickr
image37 by Jonny McIntosh, on Flickr
image38 by Jonny McIntosh, on Flickr
image40 by Jonny McIntosh, on Flickr
there's something about box fresh rear facelift lights, certainly look good against fresh paint
had them lay in place for the pic, not bolted on yet as there was still polishing to do around them
image30 by Jonny McIntosh, on Flickr
image31 by Jonny McIntosh, on Flickr
going back up to put more stuff on the car next week i think so i'll post more progress shots as i take them
thanks guys, get her back tonight, I've got to go over to the bodyshop and refit the mirrors, door cards, lights etc then she's getting transported to a garage to sit off the road until the salt's gone :) i'll also be doing the manual swap hopefully during this time since all the parts are here now
oh, also rear hockey sticks arrived today so no more rear spats for me
  • 3 weeks later...
