Help please! Exhaust/Suspension
Guest Jenny
Hi guys,
I'm spending a bit more time in my Supra and am looking to get a full exhaust replacement and some suspension work.
I've never modded a car before but the exhaust is too noisy and I'd like something more subtle for it, it's an NA so looking for a 2.5".
Would want a full system too as there seems to be some pretty bad corrosion on the existing exhaust. Any suggestions? How much should I be expecting to pay to have this fitted/would a garage source this for me?
Ideally would love some suspension work done too, the lowering springs in at the moment are way too uncomfortable, where might I find some comfortable springs? Or would you recommend ditching them entirely for coilovers (which seems like a bit of a waste as I won't be racing around anywhere!).
Thanks!!!
Hi Jenny and :welcome:
Perhaps fit a stock NA exhaust would be the way to go, must be loads of those knocking around and be quite
cheap.
The stock suspension is coilover just not a platform adjustable type, again perhaps the stock set up would be
the way to go. I'd be speaking to Chris Wilson who is a member on here who could give you a set up of exactly
what you want
If you want an aftermarket exhaust my opinion would be to use a wifbitz 2.5" twin box, I had one fitted on my old na with double decats and it was very quiet even on wot, bit still a lovely sound. Only issue is they don't make them anymore but second hand they seem to be cheap these days as no one wants quiet systems.
In regards to suspension as said above drop Chris Wilson a email he does some superb setups which will fulfill all your needs
/QUOTE]
:hello: what he said about the whifbitz 2.5", have one on mine, not far off stock volume. If you can find one secondhand. Pay the members fee then you can post wanted ads etc. There was a stock turbo exhaust on here a while back, apparently they fit the NA?? And yes Chris Wilson is the man for suspension.
