mkiv na-tt aristo wiring
jonny mac
hi guys, so i've bought an n/a auto mkiv finally
i'm looking at an engine for sale just now which is a 2jz vvti from an auto aristo
i'm wondering, is there a write up somewhere that shows you the loom mods needed? i know that it wont plug and play
i'm also aware that i'll need to change the water pump, fit a brake booster fitting into intake and something else to the engine to make it work in a mkiv shell
i'll be doing a manual swap too as i have a clutch cylinder, clutch pedal and trans tunnel on the way from japan just now for the car
anyone able to give me some advice or share a guide/knowledge on swapping them over? i can even repin my stock body loom plugs into the aristo loom if i can get a pinout diagram.
also as for ecu's, what's the deal with making an auto 2jz vvti loom work ? i would just buy a vvti 2j manual loom and ecu if i could get one for a decent price and make my life 100x easier haha
Although not much direct help, I know that if you search through old posts there is an awful lot covered already. I'm pretty sure there is something to do with the sump that needs swapping/modifying to fit in the supra chassis as well.
If you can't find anything I know on my PC I have a few saved links so can share them if someone more knowledgeable hasn't appeared before I get on it tonight
yeah mate, the sump change isn't a problem as i'll have my old n/a one to use and I should also have a spare soarer one in the loft if i don't feel like drilling the oil return out.
it's more the wiring involved that concerns me, would it be worth buying a pre terminated 2jz loom and basic stand alone ecu like a haltech rather than trying to find old second hand stuff that may not work correctly?
