Maf and map help.
zaheer0027
Hello
I'm a bit confused on maf and map sensors. I have a j spec 94 na sz.i believe it is a maf sensor. Would I be correct? Can anyone show me a picture of this sensor?
Can someone also show me a picture of an oem map sensor that came on a tt or na engine?
Because I'm going na-t I bought an aem 3.5 bar map sensor as well as an ait sensor but if I already have a oem map sensor then there is no need for me to install it.
Any help appreciated. Thanks
Maf sensor is on the intake, just after the air filter.
Map sensor will be on the inlet manifold, a small electrical sensor with a vacuum hose
/QUOTE]
Ok thanks. I'll take some pictures just to make sure 100% as this is all new to me and as I am doing all the na-t work myself I just want to make sure.
What ECU / piggyback are you planning on using, those sensors cannot be used with the stock unit.
I have an aem v2 stand alone but I have it for sale at the moment as I can't use it due to tuner not being familiar with the product. I will be using a haltech stand alone.
  • 2 weeks later...
Thanks for the above. So today I had a look at the engine bay of my na.i think this is the sensor. From looking on the net though it seems my car is map and not maf? Can someone please confirm.
First picture is the sensor in the intake with the vacuum line that goes to the plug
Second picture is the plug with the part number on it and it says SENSOR ASSY VACUUM
Hello
/QUOTE]
You'll still need to use the 3.5 bar map sensor as the stock one is probably only 1 bar absolute so won't work with pressure above atmospheric pressure
All jap spec non turbo's use a MAP based system, only the American non turbo supra's have a MAF system.
For your haltech you will need to use the supplied 3.5bar map sensor. You will also need to use an air intake temp sensor. Haltech have their own which may be worth buying if the haltech software cannot detect the stock air intake sensor.
