Not how wanted my weekend to start.
Suprakeith
Took the supra to work Friday evening and pushed her little to much having play on A1 with Astra VXR,BMW, R6 and gixer. Lost oil pressure and now have horrible rattle when idling. I suspect bottom end gone but AA man thought could just be oil pump but I dout that.
Not how I wanted to get home after work
I think oil pump failed and spun bearings, checked oil level Friday evening before used her and was fine
To be honest with the age of the cars and the engines now I think we will be seeing alot more of this in the future, engines just giving up. Any ones I've seen being rebuilt from stock these days look tired when they are pulled apart.
I wouldnt let it get you down too much mate. Just one of those things! Do your research and you'll find you can do a standard rebuild for alot less than you think!
Cheers chap and not letting it get me down to much as your right she is old car and I have used her and had a lot of joy from her, so will just swap in mates engine and then forge mine so can finally go na-t. I looking at it as opportunity to do some jobs on her and get her and give her refresh.
And the engine doesn't seem to vibrate, had mechanic mate listen and he thinks have just pounded bearing and not spun bearing as only makes noise when idle and when give her tiny rev the noise goes and she is as smooth as normal
