Help repairing Samsung Tv
MattP
Hi guys I have a Samsung 42 Inch Plasma tv Model:PS42A457P1D which I have had since 2008 however it has recently stopped turning on.
For any of you into this sort of thing you will probably of heard that Samsung Plasma screens from around this year suffered manufacturing issues with the on board power supply more specifically a few capacitors.
Moving on I have removed the rear cover which to no surprise shows the offending bulging capacitors on the power board pictured below.
Now I understand the capacitors are only a few £ and it is apparently as simple as de soldering the old ones and soldering in the new ones however I'm just looking for some clarification...
Am I ok to remove the power board and de solder these capacitors or are some parts still live?
The TV has not been plugged in for over 24 hours.
easy, the 2 which have expanded you just need to replace.
The -minus side is usually marked with a light grey strip with - - - marks on.
just replace those 2 and see how you go. i've done a similar repair cost me 32p.
The values will be on the side, you just need to buy the same then de-solder and solder the new ones in. in the SAME orientation
Fingers crossed then it should work, or the failing capacitors might have taken something else with it.
I have done loads of them, having a vacuum de-soldering iron helps, but just wiggle the cap as you alternately heat each solder pad and it will come out. Blow the molten solder from each hole, fit new caps (get 125 degree C rated ones, they last much longer and only pence dearer) and you should be good to go. Buy branded caps like Nichicon, Sony etcetera. Switch mode power supplies rectify AC mains so the big caps will have 300 V DC on them when charged, that will concentrate the mind if you get a belt off them, i have had loads, and am still just about here ;) My 5kV DC at 1 Amp supply is a different matter, I treat that with huge respect, you do not get a second chance with one of those! YouTube has dozens of videos on fixing switch mode TV supplies.
Well then gents I have de soldered the old popped capacitors as seen below.
I popped the Maplins and bought some new ones for the grand total of £1.23 got home soldered the new units in and reassembled and as you can see it was a great success.
I love the Internet..
