Day881 Posted October 25, 2016 Share Posted October 25, 2016 Hi all I recently installed some facelift indicators, and did a refurb on my pre facelift headlights. But now my front sidelights in the headlights aren't working. Every other light is working fine, the bulbs are fine as when the front fogs are on the sidelights are on. I have also checked fuses in engine and footwell, and all are fine. I also checked the ground wire and seems to be fine. Anyone got any idea what's going on? Also the indicators are wired in the way that the sidelight bit is also an indicator not sidelight Link to comment Share on other sites More sharing options...
uzzyuzzy Posted October 25, 2016 Share Posted October 25, 2016 I have the same issue too and couldn't get to the bottom of it. I have asked Lee at SRD to look into this whilst the car is being serviced. Link to comment Share on other sites More sharing options...
Big Mark Posted October 25, 2016 Share Posted October 25, 2016 Are your sidelights regular bulbs or LED? LEDs need to go in the correct way around, so you may just need to turn them 180 degrees. Link to comment Share on other sites More sharing options...
Day881 Posted October 25, 2016 Author Share Posted October 25, 2016 Are your sidelights regular bulbs or LED? LEDs need to go in the correct way around, so you may just need to turn them 180 degrees. Nope normal bulbs Link to comment Share on other sites More sharing options...
Day881 Posted October 25, 2016 Author Share Posted October 25, 2016 I have the same issue too and couldn't get to the bottom of it. I have asked Lee at SRD to look into this whilst the car is being serviced. Yh it's weird because the bulbs are working when fogs on and if it were ground wire they wouldn't work when fogs on aha if you find out what it is let me know Link to comment Share on other sites More sharing options...
Day881 Posted October 25, 2016 Author Share Posted October 25, 2016 The sidelights work fine when fogs are on but when just on first twist off stalk nothing. tail lights are on but nothing at front all fuses are fine Link to comment Share on other sites More sharing options...
Noz Posted October 25, 2016 Share Posted October 25, 2016 If everything is dead after installing a new circuit, the first thing I would do is ensure it's not shorting out and remove the new circuit. If you have installed any new wiring, make it open circuit and then check the earth is grounding out, and you have a 12v signal when the lights are turned on. Go back to basics mate! Link to comment Share on other sites More sharing options...
Day881 Posted October 25, 2016 Author Share Posted October 25, 2016 If everything is dead after installing a new circuit, the first thing I would do is ensure it's not shorting out and remove the new circuit. If you have installed any new wiring, make it open circuit and then check the earth is grounding out, and you have a 12v signal when the lights are turned on. Go back to basics mate! ok mate thanks will give that a go only new wiring is indicators soo I'll check them Link to comment Share on other sites More sharing options...
