idle control valve
Dave
so im having a problem with the car keeps cutting out and some one said clean out the idle control valve,do they get gunked up then ?
Hi mate
I had exact same issues as you (idle fluctuated a bit and cut out sometimes until it was warm) my mechanic cleaned my ICV and it's been fine ever since. I'd say that's your issue :)
Hi mate
Cheers mate will clean it
- - - Updated - - -
Is the Air sensor for the OE airbox connected?
Don't have an OE airbox
I would say that vacuum hose coming from throttle body will need replacing, if you can't get sorted, I have two ICV's spare if you need one.
Thanks mate will do that ,will get back to you if I need an icv ,never removed it before .
