Dave Posted October 23, 2016 Share Posted October 23, 2016 (edited) Ok just checked the codes and I have 41 throttle position sensor no idea how to fix or what to do can anyone help,car runs for 20 secs then cuts out rev needle is also jumping,when it stops engine light comes on ? Edited October 23, 2016 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 23, 2016 Share Posted October 23, 2016 Have you tried re setting the tps Quote Link to comment Share on other sites More sharing options...
Dave Posted October 23, 2016 Author Share Posted October 23, 2016 Have you tried re setting the tps /QUOTE] How do I do that ,I've had the Positive battery cable off all night? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 23, 2016 Share Posted October 23, 2016 Do you have the tsrm app there is a guide I there. You need a multimeter and some feeler gauges. James reset mine when I swapped over the the plenum and it took ten mins max. Very simple Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 23, 2016 Share Posted October 23, 2016 http://www.supraforums.com/forum/showthread.php?450071-TPS-Adjustment-Procedure-and-Testing-Procedure#/topics/450071?_k=5okeqj Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 23, 2016 Share Posted October 23, 2016 Also should add we used some speaker wires to get to the correct pins. Then just touch the multimeter to the other end of the wire Quote Link to comment Share on other sites More sharing options...
Dave Posted October 23, 2016 Author Share Posted October 23, 2016 Cheers mate will have a look Quote Link to comment Share on other sites More sharing options...
Dave Posted October 23, 2016 Author Share Posted October 23, 2016 (edited) Also should add we used some speaker wires to get to the correct pins. Then just touch the multimeter to the other end of the wire /QUOTE] Would a faulty TPS stop the engine from running ? Which one is the TPS Edited October 23, 2016 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 23, 2016 Share Posted October 23, 2016 Would a faulty TPS stop the engine from running ? Dunno mate but if the error is coming back as tps it's got to be a place to start. I may have a spare in the spare room. Quote Link to comment Share on other sites More sharing options...
Dave Posted October 23, 2016 Author Share Posted October 23, 2016 That's kind of you . Quote Link to comment Share on other sites More sharing options...
