Jellybean Posted October 21, 2016 Share Posted October 21, 2016 Hi The reflow connector on the FRP is fixed, you cannot remove or change (M14X1.5); I got a M14X1.5 female to AN6 Male , the fitting does not go all the way up the reflow connector Question: To ensure a good seal , use PTFE tape? or a Dowty seal maybe Link to comment Share on other sites More sharing options...
samdale Posted October 21, 2016 Share Posted October 21, 2016 (edited) Is the end of the male M14 fitting shaped in any way to create a metal/metal seal? The o ring on it suggests you have the wrong female fitting and it should go all the way in so that the o ring makes the seal. As a rule, parallel threads do not form a seal on the threads and rely on another method (o ring, dowty, compression metal on metal etc) to form a seal. Thread tape is used on tapered threads as it is the thread itself that forms the sealing faces. Edited October 21, 2016 by samdale (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted October 22, 2016 Author Share Posted October 22, 2016 thanks Will try speedflow , see what they suggest ; asked a few companies , they keep pawning me off to one another Link to comment Share on other sites More sharing options...
Jellybean Posted October 24, 2016 Author Share Posted October 24, 2016 Update on this , the fitting I have will work , as the female thread is a Convex Seat it will seal Link to comment Share on other sites More sharing options...
