evinX Posted October 18, 2016 Share Posted October 18, 2016 Well this has been around my mind for a while, and think it might be a project for next year when i have a week off to doodle around. Ive come up with the part numbers/list from the EPC but i want to know what i really need. Id like to do the job properly to fit the rear disc shield as i hear alot of people just trim and slip them on - NO NO for me, has anyone got a list of whats really needed? do i need all these little bits and such ive listed? FRONT CALLIPER RH - 47730-14260 CALLIPER LH - 47750-14270 DISC SHIELD RH - 47781-14160 DISC SHIELD LH - 47782-14160 ANTI RATTLE SHIMS - 04945-14110 FITTING KIT DISC BRAKE - 04947-14010 PINS - 90240-06019 X4 SPRING - 47748-14080 X2 CLIP - 90468-12021 X2 SPACER NO.1 - 90468-12021 X2 SPACER NO.2 - 47799-14010 X2 WHEEL BEARINGS - BLUE PRINT ADT38228 REAR CALLIPERS RH - 47730-14270 CALLIPER LH - 47750-14280 DISC SHIELD RH - 46503-14020 DISC SHIELD LH - 46504-14020 ANTI RATTLE SHIMS - 04946-14030 FITTING KIT DISC BRAKE - 04948-14010 PINS - 90240-06017 X4 SPRING - 47748-14090 X2 CLIPS - 47748-14090 X2 PLATE REAR DISC CALLIPER NO.1 - 47795-14020 X2 PLATE REAR DISC CALLIPER NO.2 - 47795-14020 X2 WHEEL BEARINGS - BLUE PRINT ADT38315 DISCS, PADS, NEW BRAIDED BRAKE LINES & FLUID I remember hearing that if you do the job properly on the rear you might want to fit new wheel bearings? do you need to for the front also? kev Quote Link to comment Share on other sites More sharing options...
blythmrk Posted October 18, 2016 Share Posted October 18, 2016 Hi Kev Great list I wanted the part numbers for the rear heat shields too as want to fit new ones any prices to go with the list? If the wheel bearings are not to expensive why not at the same time! Thanks Mark Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted October 18, 2016 Share Posted October 18, 2016 Replace the OEM bit's with the upgraded parts from this thread - http://www.mkivsupra.net/vbb/showthread.php?336831-Stainless-steel-caliper-pistons-Caliper-seal-kits-Stainless-UK-pad-pins Quote Link to comment Share on other sites More sharing options...
