Help please
kevin smith
It done it a few months ago, so i had it serviced, and changed the ECU cos mine had felt tip writing on it and was advised that it had been opened and worked on. i bought an ECU off another member and fitted it, but the car just wasn't as crisp as it was before, so i changed the ECU back for the old one and it was then i noticed that the numbers on the ECU's where 1 digit out. But the car was running really well until today when it started ? over fuelling again. Tomorrow i will change the ECU back and see if it runs.
Hi all i have fixed the problem, fingers crossed i changed out the original ECU and put the other one in, and it's running ok (for the wrong ECU) so I need 2jz-ge a/t number 17570/4762. i will put this in the parts wanted section.
Many thanks for you help.
Kevin.
That's not the part number for the ECU, what year is it for?
