Should the auto box gear selector have a light?
marbleapple
Evening all
I took the car out for a drive tonight and tried to put the auto box into drive but couldn't see the options (L,D,P,N etc) in the dark on the gear selector next to the gear stick (if that's what you call it).
Should the letters be lit up when you turn your lights on? If so, I assume the bulb has gone. How do you get to it and can anyone tell me the bulb size please?
I replaced mine a couple of months ago. Just remove the centre console dash trim and feel underneath the plastic selector oval (on the numbers side obv!). You will feel the wire and the bayonet fitting. Twist it out and pull the bulb out of the bayonet (keep the green plastic shroud!). The bulb itself is in any emergency bulb kit (including the tesco £5 one http://www.tesco.com/direct/autocare-universal-bulb-kit/331-5951.prd?source=others) or any old motor factors shop for a quid :)
I had a mare getting to mine, gave up and took the whole top off the selector housing in the end. If you pull the bottom of the shifter below the leather down and rotate it 90 degrees, you can lift the housing top high enough to get into the lamp. Apparently you can replace without doing that, I was just failing at any other method.
I managed it with everything in place, although I'm not promising that the bayonet it fully locked back in place ... but the working bulb is definitely 'in the hole' Lol
It all depends how OCD you are I guess :rolleyes:
(come to think of it, putting the green shroud on the new bulb is slightly OCD?)
