Group buy Project Mu HC800 UK Spec Pads
Farlane92
Hi guys,
Relatively new to posting on the forum so bear with me on this.
I've spoke with the guys at TCB Performance LTD having seen recently they're now one of very few people able to get Project Mu brake components at very competitive prices.
Discussed that there would be a great deal of interest from the supra community in these being the other options mainly being EPC that aren't in my opinion all that great. After speaking he's agreed with enough interest he can bulk order these and save a decent amount on price, currently looking for minimum 10 to 15 preorders.
As it's not me personally ordering these you can get in contact with Paul at TCB via;
tcbparts.co.uk
01579 383879
https://m.facebook.com/story.php?story_fbid=1194271067311975&id=183797998359292
I've copied all the relevant information from the group buy currently on Facebook along with performance figures of the pads below.
Here at TCB we're always looking to bring new products to market for our customers, for the ST205 and Supra JZA80 UK Spec Brakes there is currently a massive gap in the market for performance pads which we're hoping that with YOUR help we can bring Project Mu HC800 pads to the UK market!,
In order to get these to the UK Market I would need Pre Orders for between 10 - 15 Sets as I'm required to make a large initial order, to all of these customers I can offer a special offer discount which will be discounted even further if we reach 15 sets, The Retail prices on the front would be £139 + VAT and the rears would be £91.99 + VAT, however for the people who pre order these pads the prices would be £117.46 + VAT front and £77.73 + VAT for the rears, Fantastic pads at a fantastic price!
Let Me know below or in a message if you'd be interested in them and I'll add your name to my list.
Now why should I buy Project Mu pads? see below for information on the pad and competition pads,
on one end you have the lower end EBC products which are a price point which makes them a very attractive option, but on a fast road or track vehicle they just really can't stand up to the job, they also aren't very disc friendly, create a huge amount of dust and are noisy, they also still fade when the going gets tough,
there are much better options on the market such as Carbotech but again these can be noisy and dust, then there are Porterfield pads which we can supply and are fantastic pads, low dust, disc friendly and not too noisy a fantastic pad, the only downside to them is price and high temperature ranges really
However there is a solution we're looking to become the only stockists in the UK for Project Mu HC800 pads front and Rear for the ST205 and Supra JZA80 UK Spec Brakes, these pads are Genuine Japanese Racing Pad's they work straight out of the box and right the way up until 800 degrees one of the largest operating temperatures around the intial bite will not be the same when they are cold but brake efficiency is not completely lost when cold, but once you've done a couple of stops they're fully up to temp and ready to put in some serious braking force
with an average friction coefficient of 0.38 - 0.62 across their temperature range,
Fade Resistance
When brake pads operate at high temperatures, high pressure gases can be created in the pad and can cause a 'gas layer' between the pad and rotor. This can make the driver feel like the brakes have lost performance as the brake pedal feels the same, but the car won't slow down as normal. This phenomenon is known as 'fade'. A slot is manufactured in all Project-Mu pads to offer the gases an escape route.
Noise Suppression
Brake pads manufactured without a chamfer on the leading edge of the friction material, are more likely to produce unpleasant noise. This noise known as brake squeal is actually a high frequency vibration created by the friction between pad and rotor. The vibration can manifest in calliper, rotor or suspension vibration. This 'problem' is reduced or eliminated by the chamfer on the pad material.
Heat Treatment
Project-Mu brake pads are subjected to heat treatment as part of the manufacturing process. This process 'burns out' unwanted materials in advance, reducing the gases that can cause fade. As a result, Project-Mu brake pads only need light 'bedding in' to match the pad to your rotor surface.
HC800 has more bite than both NS and B-Spec and has excellent fade resistance. Capable of operating at temperatures up to 800°c, this pad will handle almost all serious braking conditions.
HC800 is a genuine ‘cross over’ pad suitable for both road and race.
HC800 is extremely capable in competition environments so use this pad if you are involved in serious track day, rally etc.
Along with temperature capabilities, HC800 is renowned as a ‘drivers pad’ with unmatched driver feel and control.
Fade Resistance
Noise Suppression
Brake pads manufactured without a chamfer on the leading edge of the friction material, are more likely to produce unpleasant noise. This noise known as brake squeal is actually a high frequency vibration created by the friction between pad and rotor. The vibration can manifest in caliper, rotor or suspension vibration. This 'problem' is reduced or eliminated by the chamfer on the pad material.
Heat Treatment
Brake Pad Structural Stability
Brake pads are subjected to huge pressure from calliper pistons in unequal proportions across the pad. Brake pads must remain flat to offer optimal performance so Project-Mu use only the highest grade quality steel at the correct thickness to ensure this stability. Project-Mu pads are up to 20% stronger than some competitors.
We Can Supply all of the previously mentioned products be it EBC, Carbotech or Porterfield so if you'd like one of these options then let me know and I can quote for you, but I'm keen to get Project Mu to the UK market and I'll be running them on my own ST205 and currently run them in my Track EP3 as well
Thank you for your time and I hope that you're interested in this venture
Paul Pridham
Company Director
This topic is now closed to further replies.
