Guest Rsb Posted October 11, 2016 Share Posted October 11, 2016 (edited) Hi, I've noticed that there is no ABS light on start up. I cannot see where it should be as I managed to take dash apart and replace some bulbs and all other lights work as normal. Looking at some pics, it seems JDMs had ABS light where 'Security' light is on UK cars. My question - do UK cars have a formal ABS light and if so where should it be on the cluster? Brakes seem to be working fine. Thanks again. EDIT - took dash apart and found light. Bulb is working as tried it in another slot. Both fuses present too under bonnet. Any reason why light itself wouldn't come on if system is working? Edited October 11, 2016 by Rsb (see edit history) Quote Link to comment Share on other sites More sharing options...
fastcar Posted October 11, 2016 Share Posted October 11, 2016 Split in the wire maybe. Or has been connected to hide an ABS fault! How do you know the ABS is working? Quote Link to comment Share on other sites More sharing options...
Guest Rsb Posted October 11, 2016 Share Posted October 11, 2016 Only from braking hard and 'feeling it' but fair point. More Investigations needed! Quote Link to comment Share on other sites More sharing options...
fastcar Posted October 11, 2016 Share Posted October 11, 2016 Only from braking hard and 'feeling it' but fair point. More Investigations needed! There could be a dry joint on the back of the build holder maybe Quote Link to comment Share on other sites More sharing options...
Guest Rsb Posted October 12, 2016 Share Posted October 12, 2016 Thanks fastcar, I read that somewhere else too. Electrics and soldering are beyond my skills. Might have to ask Eurospec to take a look. Quote Link to comment Share on other sites More sharing options...
