Dave Posted October 9, 2016 Share Posted October 9, 2016 So I had the alternator refurbed ,went to start and nothing just spinning over ,took off the fuel line and got no fuel coming through ,also can't hear the pump going with ignition on ,looks like a faulty pump ,is there anything else to check ?, Btw I have fuel in tank . Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 9, 2016 Share Posted October 9, 2016 Fuel pump ECU, in the diagnostic port identify ports Fp and B+. Use a paper clip to bridge the terminals, fire it up. If it works its the ECU, if not its the pump.Be careful because the clip will get VERY HOT. Take it you've checked the fuses? Quote Link to comment Share on other sites More sharing options...
Dave Posted October 10, 2016 Author Share Posted October 10, 2016 Fuel pump ECU, in the diagnostic port identify ports Fp and B+. Use a paper clip to bridge the terminals, fire it up. If it works its the ECU, if not its the pump.Be careful because the clip will get VERY HOT. Take it you've checked the fuses? Yes checked fuse but not relay gonna check that tonite,I guess your tip bypasses the ECU Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 10, 2016 Share Posted October 10, 2016 The fuel pump has its own ECU so yes it basically bypasses it Quote Link to comment Share on other sites More sharing options...
Dave Posted October 12, 2016 Author Share Posted October 12, 2016 The fuel pump has its own ECU so yes it basically bypasses it thanks swampy Quote Link to comment Share on other sites More sharing options...
OWEN Posted October 12, 2016 Share Posted October 12, 2016 check the THROTTLE POSITION SENSOR the wire on my car got loose somehow , and i had the same issue, also check if the plugs are wet Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted October 12, 2016 Share Posted October 12, 2016 I have a spare UK spec fuel pump if you want to use it and check if its pump. Just cover postage Quote Link to comment Share on other sites More sharing options...
Dave Posted November 8, 2016 Author Share Posted November 8, 2016 I have a spare UK spec fuel pump if you want to use it and check if its pump. Just cover postage Thanks for the offer mate but I got one from keron ,sorry for the late reply Quote Link to comment Share on other sites More sharing options...
ashloys Posted November 8, 2016 Share Posted November 8, 2016 I have a spare UK spec fuel pump if you want to use it and check if its pump. Just cover postage Kudos for being a legend in someones time of need, even if he got sorted before he read your post! Quote Link to comment Share on other sites More sharing options...
Dave Posted November 11, 2016 Author Share Posted November 11, 2016 Kudos for being a legend in someones time of need, even if he got sorted before he read your post! Quote Link to comment Share on other sites More sharing options...
