Main beam healight bulb help
Andrew K
I need to change my headlight main beam bulb and I'm having trouble finding a replacement! I just bought one from my local car parts place and it said on there computer it was the correct bulb for my car, when I got home and tried it the bulb didn't fit :(
On the bulb below it has koito, 12v 55w, PAT 4500946
What have you guys used or can anyone help me out where to find a bulb like in the pictures below?
You'll find 2 of the three locating lugs fit so all you need do is file off the misaligned lug and all will be well as it'll still seat properly with the two remaining lugs. That's a lot cheaper option to sourcing the jspec bulb.
Alternatively if you loosen/remove the rings on the back of the headlight (3 small screws) the bulbs will fit without modifying the tabs.
