UK Spec Turbo's on Jspec 2JZ-GTE
ashloys
I'm about to replace my jspec turbos very shortly with some UK spec turbos which I've already purchased. I basically got the turbos as a bolt on replacement with the manifold etc all still bolted on.
I've had a look around and couldn't get any definitive info on what is different/needs changed whenever replacing them i.e. is it JUST the manifold is different or is it the manifold AND downpipe need changed? If I can't get a UK spec downpipe, can I buy anything aftermarket to do the same job?
So I'm basically just looking for a list of things that I need to get/buy and what needs done basically.
Please only answers from people who have done this themselves and know 100%, no umms or aahs guessing what may or may not work/fit :D
Do you not believe me when I tell you stuff? lol
No more so than any steel hybrid replacements? I personally wouldn't worry too much about that.
Yea agreed and as regards EGR etc, delete that anyway if not already gone. Not required. Mine passes emissions without it by a country mile
You will need a UK CAT1 bypass or stock UK CAT1 as the flange is different ;)
EDIT: its also worth mentioning that they perform differently to JSPEC so the fueling and ignition will likely be out too.
Presumably as the UK turbos flow less, and are slower spooling, it will still be safe on J spec mapping (though obviously not ideal)
