couple of Q's on TT VVTI power delivery, remap possible?
wrighty338
Hi guys, really new to supras so not sure what to expect after only 1 drive - can anyone offer up some guidance?
I picked up my vvti tt supra at the weekend...iv only driven it for a day and the mods are: uprated fuel pump, Nur spec exhaust, and a blitz boost controller. Intake and intercooler are standard. it looks to be running 1 bar boost
I have a dyno print of the car at 390bhp so its fast enough while i learn the car - however it seems that when it comes on boost it comes on rather strong and 'all at once' is this normal power delivery for a vvti twin turbo?
The car feels great im not complaining at all as its a lot of fun, but is it possible to remap the stock ecu or install a piggyback chip to do so or is this generally a waste of time? im considering a fmic if this is the case simply as this will bring it in line with a 410bhp bpu install but otherwise il just save my money and keep it twinned until i can afford a single turbo kit and standalone ecu.
Edit: will the stock twins struggle to fill a 4' fmic kit?
cheers
Edited by wrighty338 (see edit history)
You may have the turbo's in true twin and not stock sequential. Look up ttc or true twin conversion on here and check your vsv's pipework.
You should get 0,7-0.8 bar on the first turbo fairly quickly and it hold there till close to 4000rpm, do you? Or does boost pressure build more slowly to max boost?
