berg Posted October 1, 2016 Share Posted October 1, 2016 Does anyone have any ideas on where i can find a 95-76mm (3.75"-3") 45 degree silicone elbow in Black Ive looked on every silicone hose place i can think of including google and ebay search Closest ive found is 90 degree on ebay which is no good Most top places go from 90 straight to 102 and dont list 95 at all My 90mm throttle body has a 95mm outer diameter just to make things harder Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 2, 2016 Share Posted October 2, 2016 (edited) I think you either need to have a 1 off hose made or modify your set up. You could use this size hose and have a sleeve turned to fit to the throttle body to raise the diameter up to the hose size, or you could add to the outside of the intercooler pipe to raise that size up possibly Or have the bend you need fabricated in Aluminium.st/st tube then use straight couplers at each end http://www.ebay.co.uk/itm/TOG-3-4-INCH-76-102MM-45-DEGREE-SILICONE-HOSE-REDUCER-BEND-ELBOW-BLUE-125MM-/111119995506?hash=item19df449272 Edited October 6, 2016 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
